This is a discussion on Warning light won't shut off within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; on my 2010 gen 3, there is a red flashing light on the dash after I lock the car. I ...
Old 10-10-2009, 07:30 PM   #1
suebeewankenobi
Package: Navigation
Default Warning light won't shut off
on my 2010 gen 3, there is a red flashing light on the dash after I lock the car. I looks like a door with a 'lock' flashing on it. I can lock the car, but the lock does not go off.
suebeewankenobi is offline
Old 10-10-2009, 07:39 PM   #2
Econ
Econ's Avatar
Model: V
Package: Navigation
Default Re: Warning light won't shut off
perhaps it is the anti-theft indicator for the electronics?or alarm status indicator
Econ is offline
Old 10-11-2009, 01:06 AM   #3
jayvee
Package: Navigation
It's an anti-theft indicator. Makes thieves unsure if there's an alarm.
jayvee is offline
Old 10-11-2009, 04:27 AM   #4
pinzvidz
Generally in most Toyota vehicles the "Security" LED or immobiliser symbol will remain lit for the first 30 seconds or so when you lock the car, then it will flash every (approx.) 2 seconds, to warn dropkick would-be thieves that your vehicle is fitted with some sort of security device.
pinzvidz is offline
Old 10-11-2009, 08:31 AM   #5
As pointed out above, it's the immobilizer light showing that it is active, or in other words, an anti-theft warning light.
You should be congratulated on noticing it so soon. Many new owners don't notice it for the first six months or a year, and then come on PriusChat and post something like "NEW WARNING LIGHT ON DASH! WHAT DO I DO?" It takes a lot of typing to convince them that it has been there all along, while they were looking elsewhere.
The Following 2 Users Say Thank You to qbee42 For This Useful Post:
JuJu and Me (11-04-2009), patsparks (10-11-2009)
Old 10-13-2009, 01:54 AM   #6
HI MPG
HI MPG's Avatar
I just noticed it today also, which surprised me a bit because I parked it in my garage...UNLOCKED.
HI MPG is offline
Old 10-16-2009, 07:44 PM   #7
Bear68
Friends: 7
The immobiliser indicator light comes on when the car is turned off. It shows that the car cannot be started without a registered key in the car. Most Toyotas now have immobiliser systems and those with standard keys will shut off the light simply by inserting the key into the ignition. Gen II Prius turns off the light by putting the key fob into the dash slot.
Bear68 is offline
The Following User Says Thank You to Bear68 For This Useful Post:
Mr. Bill (10-16-2009)
Old 10-16-2009, 07:51 PM   #8
HI MPG
HI MPG's Avatar
Thanks. I would think that the warning light would flash once the doors are locked. But I guess that it would also make sense that the light flashes without the doors being locked for those instances when they are accidentally left unlocked when leaving the car...
HI MPG is offline
light, shut, warning
Automatic head light leveling system warning light mmirman Gen II Prius Care, Maintenance and Troubleshooting 9 Yesterday 08:27 PM
Any way to get airbag light to shut off? Spiral Gen III 2010 Prius Main Forum 3 08-04-2009 01:08 AM
Master Warning Light/Hybrid System Warning panache Generation 1 Prius Discussion 6 07-20-2009 10:06 PM
red brake warning light and abs light on shocker Gen II Prius Care, Maintenance and Troubleshooting 1 04-23-2008 10:15 PM
Red warning light?..... Dinger Gen II Prius Care, Maintenance and Troubleshooting 2 08-11-2004 10:51 PM
