This is a discussion on what oil filter and washer within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by ken1784 - Loosen the filter cap four turns, then locate the index rib(*2 on the following picture) ...
Old 10-22-2009, 06:53 AM   #11
datrays
datrays's Avatar
Default Re: what oil filter and washer
Originally Posted by ken1784 View Post
- Loosen the filter cap four turns, then locate the index rib(*2 on the following picture) at the top or bottom for oil draining from the cap.
Ken@Japan
Is the purpose of this so the oil doesn't drain all over the place. How would that help if *2 is on top?
datrays is offline
Old 10-22-2009, 09:10 AM   #12
a64pilot
If I remember correctly there is a rib that will cause the oil to stick to and drain from the rib as opposed to running from one side then the other. Not real important, just neater, less mess. I believe there are two ribs, 180 deg from each other
Of course I have been wrong before.
a64pilot is offline
Old 10-22-2009, 09:58 AM   #13
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
You are correct, there are two drain slots as shown in Ken's drawing (*2), they seem to do the job and most of the oil comes out of the cap when you locate one of them at the bottom. As it says, the cap needs to be loosened 4 turns before it can drain.
tumbleweed is offline
Old 10-22-2009, 11:17 AM   #14
ken1784
SuperMID designer
ken1784's Avatar
Package: G
Friends: 8
We can see the drain slot on the screw thread of the cap from the John's document page-12.
Ken@Japan
ken1784 is offline
Old 10-22-2009, 12:34 PM   #15
Mr. Bill
Model: II
Originally Posted by hotbrass View Post
Where is everyone getting their oil filters and drain plug washers from for the 2010 Prius? Using Mobil 1
Best price?
Hi,
Got my filter from 'One Stop Auto'
You need to go to a full service auto parts store (NAPA / etc) - they needed to look it up on there computer and get me the filter.
The o-ring is included with the filter (you may want to verfiy)
Check you my Standard work - step by step change procedure including pictures if you are interested.
Also - I use Mobile 1 ..... second to none for overall performance and results.
I hope this helps - Bill
(wrenches - 64mm for the filter and 17 mm for the oil pan)
Mr. Bill is offline
Old 10-22-2009, 05:03 PM   #16
tumbleweed
tumbleweed's Avatar
Model: V
Here is where I ordered mine: TRDparts4u accessories for your Toyota car, truck, 4x4 or SUV with Genuine Toyota and offroad specialty parts.
Here are the individual pages for the items.
Toyota filter elements 10 for $46 includes shipping:
Genuine Toyota Cartridge Oil Filter FREE SHIPPING! 04152-YZZA6-CASE10
Drain Plug gasket 10 for $14 includes shipping:
(10) Oil Plug Gaskets (a must for each oil change) 90430-12031-BAG10
Old 10-27-2009, 07:30 AM   #17
triumph1
triumph1's Avatar
Originally Posted by Mr. Bill View Post
Hi,
Second to none? I don't know about that......
triumph1 is offline
filter, oil, washer
Low Washer Fluid Light Tideland Prius Gen III 2010 Prius Main Forum 19 02-06-2009 07:53 PM
Engine air filter - upper filter? petteri Gen II Prius Care, Maintenance and Troubleshooting 8 12-03-2008 09:59 AM
For Sale Cabin Filter, Oil Filter, Engine Filter moolman Private Sales 6 06-25-2008 08:23 PM
Crush Washer : Try this ? smokey1 Gen II Prius Care, Maintenance and Troubleshooting 2 04-10-2007 01:17 AM
Washer Fluid maggieddd Gen II Prius Main Forum 7 02-23-2006 08:19 PM
