This is a discussion on 9V Module in 12V Outlet to Save Presets? within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; A co-worker was telling me this morning about going to AutoZone to replace a battery. He said first the technician ...
Old 10-28-2009, 12:35 PM   #1
jdcollins5
Package: Navigation
Default 9V Module in 12V Outlet to Save Presets?
A co-worker was telling me this morning about going to AutoZone to replace a battery. He said first the technician inserted a 9V battery module in his 12V outlet to save his presets. He removed the battery and replaced with a new one. All radio presets were saved.
Has anyone else heard of this and specifically has anyone done this on their Prius? Sounds like a great idea, especially with all of the presets on the Nav units.
jdcollins5 is offline
Old 10-28-2009, 03:02 PM   #2
jdcollins5
Package: Navigation
Default Re: 9V Module in 12V Outlet to Save Presets?
After creating this post I thought about reading other posts that stated that the 12V outlet is not connected to the 12V battery when the system is off. Others had discussed using this as a way to charge the battery when leaving it for extended periods of time.
Is this correct?
Sorry. Has anyone heard of using the 9V module on non-Prius vehicles?
Old 10-28-2009, 03:25 PM   #3
rrolff
Prius Surgeon
rrolff's Avatar
Is this correct?
Both 12V outlets are switched - and off when the car is off. Plugging anything into them when the car is off does nothing. That said, most of today's radios keep the data in FLASH, so the settings are saved.
If you want to do something out of the ordinary, you could sire one of the outlets directly to the battery...
rrolff is offline
Old 10-28-2009, 03:47 PM   #4
If you want to save presets during a battery swap, connect another 12V source to the jump points under the hood. This will float the bus during the swap.
Alternately, you can switch the Prius on and swap the battery while the car is powered up. The DC to DC converter will keep the 12V bus powered during the replacement. This method makes me a bit more nervous because of the risk to powered up components. Either way, be vary careful to avoid shorts and polarity reversals.
qbee42 is online now
Old 10-28-2009, 03:48 PM   #5
jdcollins5
Package: Navigation
rrolff
Thanks,
Dwight
Old 10-29-2009, 09:14 AM   #6
hobbit
hobbit's Avatar
I have explored this somewhat, using a direct keepalive on the 12V
... but I did use 12 volts. I suspect that most of the memory
keepalives internally use 5V, and if you feed enough voltage to get
above the minimum running threshold of the little regulators inside
the ECUs then 9V might be enough to keep the memory alive.
But not through the power outlets, for the reasons stated.
_H*
hobbit is offline
Old 10-29-2009, 09:31 AM   #7
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 20
What about using the vehicle jumper plug in the front. Of course there is the potential for a little fight:
12 VDC, 600 A. auxillary battery vs. 9 VDC 450 mAH
I'd probably want to use a pair of 6 V lantern batteries and possibly a diode to prevent reverse current flow.
bwilson4web is offline
Old 10-29-2009, 10:04 AM   #8
jdcollins5
Package: Navigation
If you used the 9V battery, I think you definitely want to use the diode when you first plug it in with the 12V battery still in service to block the higher voltage. Once the battery is removed then the 9V current could flow to the ECU to keep the presets. Connecting it to the front jumper bar seems like the best idea since the 12V outlets are not connected when off.
My co-worker was going to go by AutoZone and get some info on this 9V module that they used. Evidently this module must contain the blocking diode if he plugged it in to the 12V outlet prior to removing the battery. Of course you could easily make your own like the one you show in your picture. I need to look in to this.
Old 10-29-2009, 10:27 AM   #9
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 35
This idea worked well on most conventional cars but for the above reasons it does not work on the Prius unless you have the 12v outlet mod that Coastal Electronics sell swhich allows the use of the 12v outlet even when the car is off.
F8L is offline
12v, module, outlet, presets, save
How Do I Change NAV Presets? MAPC Gen III 2010 Prius Audio and Electronics 4 10-04-2009 01:06 AM
How do I add XM presets for Gen III w/NAV? dk2463 Gen III 2010 Prius Audio and Electronics 5 07-12-2009 10:42 AM
Center Console Power Outlet and Front (Cigarette outlet) How to mod Always hot?? Prius07Pkg4 Gen II Prius Audio and Electronics 15 01-18-2009 11:37 AM
Radio Presets Skipdvs Gen II Prius Audio and Electronics 6 12-08-2008 08:41 PM
radio presets jkash Gen II Prius Audio and Electronics 3 01-23-2004 01:49 PM
