This is a discussion on Tree sap removal HELP!!!! within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; I used acetone with no ill effects. If you're not sure about a particular paint job, test it on an ...
LinkBack (1) Thread Tools
Old 11-03-2009, 10:33 PM   #11
hobbit
hobbit's Avatar
Default Re: Tree sap removal HELP!!!!
particular paint job, test it on an obscure area like inside one
of the doorframe areas and look for clearcoat cloudiness at a
minimum. I didn't totally soak the area, just used enough to
loosen the sap and slide it off.
_H*
hobbit is offline
Old 11-04-2009, 08:46 PM   #12
andrewclaus
Always try to dissolve something with a solvent of like properties. Don't use petroleum products on sap from a tree. Alcohol comes from plants. Alcohol works great on removing tree sap and doesn't harm paint. An easy dab with a damp cloth and it's gone. I parked my car outdoors in Evergreen, CO for the first two years of its life and had this issue a lot.
andrewclaus is offline
Old 11-05-2009, 05:28 PM   #13
johntt
I know this is going to sound weird, but try using a little bit of mayo and a paper towel. Make small circular motions on the sap and it should start dissolving away. I tried it on my previous Audi and it worked like a charm, other than the fact that I wanted to slap on a piece of deli meat and bread.
johntt is offline
Old 11-05-2009, 05:40 PM   #14
wintechsw
Package: I-Tech
The universal stain/glue/chewing gum/road tar remover in Oz is eucalyptus oil on a damp sponge/cloth. Just a few drops does the trick for most situations, just rub it off. Then wash the area with soapy water.
We buy it at the supermarket here, I don't know whether you can get the oil in the US but you you do have eucalyptus trees in California.
HTH
wintechsw is offline
Old 11-06-2009, 03:24 PM   #15
LakePrius
Model: II
We get a lot of tree sap here. I've always used rubbing alcohol to take the sap off. Never have seen any damage to the paint/clear coat as a result.
LakePrius is offline
removal, sap, tree
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-care-maintenance-troubleshooting/71435-tree-sap-removal-help.html
Tree sap removal HELP!!!! - PriusChat Forums This thread Refback 11-01-2009 03:46 AM
Tree Hugs Tree Hugger's Car Doc Willie Prius and Hybrid News 1 08-14-2009 02:48 AM
me vs. tree iraqiswhack Fred's House of Pancakes 10 12-22-2008 09:44 AM
Not a tree hugger... CLEEVE Fred's House of Pancakes 33 05-22-2008 03:53 PM
Barqueing up the right tree? tripp Environmental Discussion 10 04-25-2008 12:52 PM
