| This is a discussion on Poor centering of steering wheel after slight movement within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; Hi from Norway Spartane and thanks for your interesting comments! To day I was visiting the dealer to explain about ... |
| | #11 |
| Junior Member Join Date: Oct 2009 Location: Oslo,Norway
My Car: 2010 Prius Model: N/A Package: Executive Thanks: 0
Friends: 0 | Hi from Norway Spartane and thanks for your interesting comments! To day I was visiting the dealer to explain about this phenomenon and the garage manager took my car for a drive. He also noticed this poor centering issue but after a test drive with the company`s demo car, we both concluded that this car also suffered from a similar behaviour. So, the garage manager believed this to be a "normal" behaviour for this car model. However, I am not satisfied with this conclusion, as on other Toyota cars with EPS I have not noticed this problem. So, I will talk to the distributor`s technical dept. and see if they have any TSB from Toyota in Japan as for reprogramming of the EPS system. The behaviour is very annoying when driving straight forward on the freeway. Maybe more of you guys with 3 gen. Prius could check out this when cruising on the freeway in the times to come.... |
| | #12 | |
| Senior Member Join Date: Jul 2008 Location: California
My Car: Other Hybrid Model: Package: N/A Thanks: 4
Friends: 2 | It has nothing to do with the EPS, self centering force comes from the caster angle of the front wheels. If you have ridden a bike or bicycle, you know what I mean. Toyota cars are mostly using McPherson strut suspension like in the Prius, which limits the amount of caster can be dial in without sacrificing cornering force. This is why for good handling cars they always have double wishbone suspension. I suspect the Toyota you claim to have good centering may have double wishbone suspension (some European version may have a different suspension setup then the US version) or it is a Lexus. Quote:
| | #13 |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 126
Friends: 33 | Prius steering does feel different to most cars. You get used to it. As others have said, check your wheel alignment. |
| centering, movement, poor, slight, steering, wheel |
| Prius steering wheel | ETP | Gen II Prius Main Forum | 11 | 05-04-2009 06:47 PM |
| Dark Steering Wheel | carlson.dl@sbcglobal.net | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 11-09-2007 01:59 PM |
| Poor steering and handling on the highway. | Mike N | Gen II Prius Care, Maintenance and Troubleshooting | 134 | 11-14-2005 12:46 PM |
| Free Fix for poor steering and stability? | dbarry | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 06-19-2005 11:03 AM |
| Steering wheel size? | PeeDeePrius | Gen II Prius Main Forum | 4 | 05-22-2005 04:25 PM |
