This is a discussion on How to turn the gas engine "on" after oil change (?????) within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; Basic question - haven't seen much on it... Now I know I wanted 4.25qts, so we went with that - ...
Old 11-04-2009, 04:19 PM   #1
rrolff
Prius Surgeon
rrolff's Avatar
Default How to turn the gas engine "on" after oil change (?????)
Basic question - haven't seen much on it... Now I know I wanted 4.25qts, so we went with that - but the mechanic wanted to "check it" after changing.
We could find no way (in the bay) to turn on the engine. I went to pwr mode to no avail... How do you turn on the engine???
rrolff is offline
Old 11-04-2009, 04:21 PM   #2
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
Default Re: How to turn the gas engine "on" after oil change (?????)
Turn the car on in the normal fashion, leave it in park then push the gas pedal down and it will start.
tumbleweed is offline
Old 11-04-2009, 04:40 PM   #3
paprius4030
paprius4030's Avatar
You can also just put it on defrost and max heat that will keep the ICE running.
paprius4030 is offline
Old 11-04-2009, 10:48 PM   #4
ken1784
SuperMID designer
ken1784's Avatar
Package: G
Friends: 8
Then, place it in neutral. The engine will continue to run.
Ken@Japan
ken1784 is offline
The Following 2 Users Say Thank You to ken1784 For This Useful Post:
robinson (11-05-2009), rrolff (11-05-2009)
Old 11-05-2009, 05:08 PM   #5
spiderman
Prius I am
spiderman's Avatar
Model: II
Ken@Japan
I wonder for how long? Guess I will have to try... thanks.
spiderman is online now
Old 11-05-2009, 06:19 PM   #6
a64pilot
I think until it runs out of gas. I don't think the traction battery is charged in neutral either, so eventually you will get a message telling you to put the car in park.
I haven't done it though, so not sure.
a64pilot is offline
change, engine, gas, oil, turn
Turn Signal "Clicker" aparks1569 Gen II Prius Main Forum 6 12-03-2007 12:07 AM
Is there a way to turn off the "negative" view? yarzy Gen II Prius Main Forum 5 10-06-2006 02:16 PM
If home right now, turn on ABC's Nightline, doing a show on "Hybrid Hostility" BoosPrius Gen II Prius Main Forum 3 04-22-2006 01:12 PM
"Engine Start Stop" vs. "Power" Buttons paulisme Gen II Prius Main Forum 2 04-21-2004 08:04 PM
