This is a discussion on Is High Pitch Squeaking Noise From Wheel Normal? within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; I had my rear brakes de-glazed the last week of December. They're still virtually squeak-free (I've heard an isolated squeak ...
LinkBack (1) Thread Tools
Old 01-31-2010, 12:04 AM   #11
Dark_matter_doesn't
Dark_matter_doesn't's Avatar
Default Re: Is High Pitch Squeaking Noise From Wheel Normal?
I had my rear brakes de-glazed the last week of December. They're still virtually squeak-free (I've heard an isolated squeak in the morning). If it comes back, I'll try the anti-squeak compound on the brake pad back plates.
Dark_matter_doesn't is offline
Old 02-11-2010, 03:52 AM   #12
constellazn
Package: Navigation
I've had the same problem when I accelerate so I recently took it into the dealership. The shop foreman was able to hear the squeaking sound and later told me that they worked on the rear brakes. When I got my car back I noticed that the squeak became louder.
constellazn is offline
Old 02-12-2010, 10:45 PM   #13
toyolover
Package: Premium (Canada)
Squeaking noise from brakes, especially in a early cold morning, is not uncommon. The reason is when you come back from a trip, the brake discs are hot. As soon as you park the car, the hot disc metal contacts the cold air with the moisture. Oxidation occurs almost immediately and a thin (almost invisible) layer of rust will form. When you drive the car away the next day morning, the first few applications of the brake will wear off this "rusted" layer and this causing the noise. The noise should be gone within a few hundred feet or after applying the brakes a few times. However, if the noise is still audible when you apply the gas, then I suspect adjustment of the brake pad is needed or even may be a slightly warpped disc. If this is the case, machining of the disc is required but doing this would also reduce the thickness of the disc. A disc can only be machined one or two times. Anti-squeaking compound is not a permanent cure. An imperfect brake pad may also cause the noise.
toyolover is offline
high, noise, normal, pitch, squeaking, wheel
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-care-maintenance-troubleshooting/71783-high-pitch-squeaking-noise-wheel-normal.html
Is High Pitch Squeaking Noise From Wheel Normal? - PriusChat Forums This thread Refback 12-11-2009 06:06 PM
High Pitch Noise dmeyer Gen III 2010 Prius Care, Maintenance and Troubleshooting 17 07-31-2009 12:00 PM
High pitch noise from engine brwnjr82 Newbie Forum 7 10-07-2008 09:17 AM
High pitch noise from engine brwnjr82 Gen II Prius Main Forum 1 09-26-2008 04:10 PM
Faint, High-Pitch Whine IndyDoug Gen II Prius Care, Maintenance and Troubleshooting 6 03-02-2006 06:14 PM
High pitch whistle when starting off norman Gen II Prius Care, Maintenance and Troubleshooting 5 10-01-2004 12:50 AM
