Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010 Prius Fuel Economy
This is a discussion on Is driving for maximum mpg worth the trouble? within the Gen III 2010 Prius Fuel Economy forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by WPWoodJr . . . My goal is to get pretty good mileage without too much effort. . ...
Old 07-19-2009, 06:39 PM   #61
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 20
Default Re: Is driving for maximum mpg worth the trouble?
Originally Posted by WPWoodJr View Post
. . . My goal is to get pretty good mileage without too much effort. . . .
Let me suggest a couple of guidelines:
  1. Map alternate routes - use Google or other map resources to identify alternate routes to and from work. If you can find optimum route(s) between work and home, you'll gain an easily reproducible way to save fuel.
  2. Choose the right lane, speed limit - listen to tunes and let the traffic flow.
  3. Follow slow pace vehicles - there are often trucks or SUVs with 'handicap' tags or big cars with older drivers or loaded pickup trucks towing a trailer who run slow. Follow them at a safe distance and let the world pass on by.
  4. Anticipative braking - it is better to brake to say 25 mph early and coast up to a red light. A gamble, sometimes the light changes and you've kept your kinetic energy to roll on through.
  5. Vehicle maintenance - lubricants and quality fuel
ALTERNATE ROUTE
My route is broken into three phases:
  1. warm-up - the first 1-2 miles is through the neighborhood at 20-25 mph. This minimizes loading the engine while it warms up. A cold engine is the least efficient.
  2. cross-town - I use the two lane, access road, 40 mph, adjacent to the 50 mph divided highway. Mostly I'm in the right hand lane running at 35-38 mph. When I join an interstate, I accelerate on downgrade access roads and coast-up exits. Drive to avoid having to brake.
  3. cool-down - the last 1-2 miles is uses streets where 30 mph is perfectly OK and there is a spare lane for following traffic to pass. Often I drive using the rear view mirror and have no problem changing lanes to let following traffic pass. This lets the battery SOC convert into saved fuel.
There are 3-4 alternate routes between home and work and depending upon traffic, some work better than others. For example, Bob Wallace has a gradual downgrade, which makes it perfect for going home. But sometimes traffic is nuts so I'll turn off and head on another north-south street. Learn your possible routes, test them, and then go with what works. ... If I'm late for an important meeting, I take the fastest ... having a job is better than not. <wink>
GPS Mapping
Recently I got a Garmin nuvi and found the urban maps are pretty good for investigating routes that cut through neighborhoods. As 25 mph, a neighborhood is a great way to get from point A to point B without having to deal with impatient, cross-town traffic. I've used it to optimize my lunch routes.
Four Lanes over Two
This allows you to keep out of the way of ordinary traffic IF the traffic isn't in rush hour. Just slide along in the right hand lane and make time.
Know Your Vehicle
or
We have two Prius and they have distinctly different performance.
A hybrid specific web site.
bwilson4web is online now
mpg
Getting maximum MPG on freeway alevinemi Gen II Prius Fuel Economy 27 06-03-2009 10:18 PM
maximum speed for gliding? psikot Gen II Prius Fuel Economy 1 09-11-2007 07:07 AM
Maximum Luggage Capacity clintd555 Gen II Prius Main Forum 4 02-25-2007 07:28 AM
Maximum MPG - It can't get any better than this mtsarpilot Gen II Prius Fuel Economy 15 09-10-2006 03:22 PM
RPM at 70% maximum dachshund Gen II Prius Technical Discussion 5 09-05-2006 10:35 AM
