Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010 Prius Fuel Economy
This is a discussion on Thoughts on the MPG Variance and Data Gathering within the Gen III 2010 Prius Fuel Economy forums, part of the Gen III (2010+) Toyota Prius Forums category; Could be that a pump (supposedly accurate by state standards) was off also?...
LinkBack (1) Thread Tools
Old 07-26-2009, 11:52 PM   #11
DrJon
DrJon's Avatar
Default Re: Thoughts on the MPG Variance and Data Gathering
DrJon is offline
Old 07-28-2009, 08:54 AM   #12
DaveinOlyWA
3rd Time was Solariffic!!
DaveinOlyWA's Avatar
Costco is where i got the gas and although the state mandates pumps be calibrated every 3 years, Costco calibrates theirs every 6 months. they acknowledge that the mechanics of the pumping system do wear out and becomes inaccurate, so they take on the expense to go the extra mile to make sure the pumps are accurate.
the last time i went there which was last week for the SPM, i checked the their inspection stickers were dated 06/2009...
DaveinOlyWA is offline
Old 07-28-2009, 10:15 PM   #13
billklug
Model: II
Package: Base - CA
Just got "Bullet" out of the shop with a new paint job. Weather changed and 104F required AC to be run. AC appears to tank my MPG from historical 53 to about 46!! Perhaps I should just sweat and go for the better MPG?!? Will perform and experiment relative to AC on vs. AC off and see what the delta is; will report back.
billklug is offline
Old 08-01-2009, 11:04 AM   #14
DaveinOlyWA
OP edited with latest tank. think i probably short-filled the previous tank which accounts for part of large discrepancy on this one. last tank shut off 3 gallons to early, so filled it to estimated level of fullness. lost first bar at around 80 miles i think which is far less than normal.
Old 08-01-2009, 01:44 PM   #15
alfon
Package: Navigation
I can not pump my own gas here in Oregon, and there is a new law where once the pump clicks off you can not top off by law.
However, if I lived in a state where you could pump you own gas; I would fill to the top of the neck where you can not get any more gas in. Than I would drive say 500 miles or so. Fill up, at the same station pump, to the top of the neck. Look at what the MPG display states, than calculate miles driven and gallons used.
In my opinion this would give you a very accurate reading, and after a few tank using the same method there would be no discrepancy.
I know that there may be problems with the charcoal canister by filling up to the neck, but who here has any problems by doing that?
alfon
alfon is offline
Old 08-02-2009, 01:09 PM   #16
anne1965
Gotta love the game...
anne1965's Avatar
Model: I
Do you make short trips or long? On short trips the A/C hit is large because it goes flat out to cool the interior, and then throttles back when the set temperature is reached? If that moment coincides with the arrival at your destination...
At what temperature do you set your A/C? I usually set it at 23 C (73F I believe), I have read from others setting it as high as 78 F. This does make a considerable difference in the Prius.
anne1965 is offline
data, gathering, mpg, thoughts, variance
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-fuel-economy/65838-thoughts-mpg-variance-data-gathering.html
Thoughts on the MPG Variance and Data Gathering - PriusChat Forums This thread Refback 07-23-2009 05:15 PM
MPG variance between actual and computer? cavebutter Gen II Prius Fuel Economy 32 05-17-2008 07:09 AM
PHX Prius Gathering h2photo Local Prius Club Main Forum 19 03-24-2008 01:14 AM
Los Angeles Gathering On 2/2/08 mjms2b Local Clubs, Events, and Road Trips 0 01-27-2008 03:03 PM
Possible Answer to MPG Variance between 04-05 and 06+ Models Tideland Prius Gen II Prius Main Forum 4 02-10-2007 04:28 PM
Huge variance between computed mpg and MFD gnagel Gen II Prius Fuel Economy 10 07-05-2006 12:09 PM
