| This is a discussion on 11.9 gallons within the Gen III 2010 Prius Fuel Economy forums, part of the Gen III (2010+) Toyota Prius Forums category; Does the 3rd Gen Prius use all 11.9 gallons of gas or does it shut off before it bingos fuel? ... |
11.9 gallons
| Member Join Date: Aug 2009 Location: Los Angeles CA
Friends: 0 | Does the 3rd Gen Prius use all 11.9 gallons of gas or does it shut off before it bingos fuel? I know there are eight bars of fuel on the indicator, and if the prius uses all 11.9 gallons that would be 1.5 gallons per bar. Is this accurate, or am I missing something. I have driven 252 miles and used four bars, so my MPG is something like 41.6 MPG. I wanted to get 50! ![]() Any clarification on the max bingo fuel would be appreciated |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 229
Friends: 23 | A typical Toyota fuel tank will have the Low Fuel light come on when there's 10 litres left in the tank (~2.5 US gal). It's rare that any fuel gauge is linear. On our '05 with the bladder in the summer, I'll get ~50km per pip for the first half of the tank (After the 1st pip goes) and ~80km per pip for the second half of the tank. |
Friends: 10 | The Prius fuel gauge, like the gauge on almost all cars, is not linear. The Gen III Prius can use most of the 11.9 gallons, but don't expect it to work out to a nice even number per pip. Tom |
| Silver Lining Join Date: Nov 2005 Location: La Mesa California
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 32
Friends: 0 | Don't get tied up in trying to know exactly how much as is in your tank, it will drive you crazy, you will be wrong and you might run out of gas. Go with the computer and average each fill up against miles driven. If you live in the central area of LA and use the freeways 50mpg should be achievable. If you are in the Hollywood Hills or anywhere hilly you probably will not achieve 50 mpg. |
| Junior Member Join Date: Jul 2009 Location: Indiana
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 24
Friends: 0 | Does the 2010 still have the "bladder" type like the gen II? |
| Diehard Dolfan Join Date: Jul 2009 Location: Coconut Creek, FL
No, the 2010 doesn't have the "bladder." I've noticed that once the empty light starts flashing you still have another 50 miles or so left, I drove about 520 miles on a tank and filled up with about 10.2 gallons, so I probably could have hit 550, but as with any car it is not good to run it dry or that low. I use a combo of my avg mpg's for that tank (Trip A on my Prius) and the Miles to Empty reading. I figure once the MTE says "0" I have about 50 miles to find a gas station. Thoughts? | |
| The Following User Says Thank You to Spee1113 For This Useful Post: | Peppito (08-17-2009) |
| Senior Member Join Date: Feb 2009 Location: Western Washington
My Car: 2010 Prius Model: II Package: No Package Thanks: 22
The fuel gauge has 10 bars, not 8. There appears to be some consensus that the bars represent about 1 gallon each, on average, with about 2 gallons left after the "Miles to Empty" display reads 0. But don't expect good consistency from bar to bar, or car to car. Doing so may leave you stuck by the side of the road with an empty tank. Until you have filled your own tank multiple times, you can't have a reasonable idea how your particular fuel gauge reads. The variation among my pre-hybrids was huge, and Toyota has done little to improve on fuel gauging precision. Last edited by fuzzy1; 08-12-2009 at 04:40 PM. | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 147
Friends: 20 | Quote:
Bob Wilson | |
| Member Join Date: May 2009 Location: Los Angeles
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 4
Friends: 0 | [QUOTE= I have driven 252 miles and used four bars, so my MPG is something like 41.6 MPG. I wanted to get 50! [/QUOTE]I am in the same boat. Los Angeles is tough on MPG, especially between the hours of 8am-8pm |
| 2010 Prius owner Join Date: Jun 2009 Location: Montréal, Québec (Canada)
My Car: 2010 Prius Model: N/A Package: Premium (Canada) Thanks: 19
Friends: 0 | A quick related question: How does the tank estimated remaining distance gets calculated? Am I correct thinking it is based on the last tank travel distance? Is it an average of the last few tanks? (I went on a long trip (the car was new) with bikes on the roof (with 3-4 tanks). Since I came back home, I get a goofy estimated distance remaining as my MPG is a lot higher now that the bikes are off the roof.) |
| 119, gallons |
| What's the most gallons of gas you've filled | driveprius | Gen II Prius Care, Maintenance and Troubleshooting | 76 | 09-16-2007 05:54 PM |
| Gallons per Month | Tyrin | Gen II Prius Fuel Economy | 22 | 09-16-2007 06:44 AM |
| 221 miles, 4.02 gallons | sharkmeister | Gen II Prius Fuel Economy | 0 | 08-04-2007 08:02 PM |
| Pumped in 10.5 Gallons | pricoaster | Gen II Prius Fuel Economy | 2 | 10-30-2006 11:26 AM |
| Have you ever pumped more than 10 gallons of gas? | Vespasian | Gen II Prius Main Forum | 21 | 03-10-2006 08:25 PM |
