| This is a discussion on Uphill vs. downhill makes the biggest difference within the Gen III 2010 Prius Fuel Economy forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by ken1784 ... My car inspection sheet says 1290kg empty. I'm a skinny person, so I set 1350kg ... |
| | #41 | ||
| Senior Member Join Date: Feb 2009 Location: Western Washington
My Car: 2010 Prius Model: II Package: No Package Thanks: 78
| | #42 | |||||||||||||||||||||||||||
My Car: 2006 Prius Model: Package: #3 Thanks: 212
Friends: 63 | Prius can climb hills easy due to the huge MG2 torque. See the video below of me climbing with my wife in the passenger seat. Yes, the speed is low but so is the engine RPM (about 1,500). HSD was working like a series hybrid (such as Volt). Gas engine was making power to feed to the electric motor to get a huge torque boost. A step gear car will not be able to do it. Below is the slope of the hill in the above video: ![]() In the video below, a friend with 1996 Civic and I (with 2006 Prius) experimented with hill climbing. Although the Civic is much lighter, the engine almost stalled when the RPM gets as low as my Prius. To highlight the benefit of the synergy between gas and electric, I am going to compare and contrast the two:
__________________ Prius shaped the form of future cars. Hybrid Synergy Drive is the engine of change that moved us forward. Luxury: Sherwood Wood Dash | Bartlett Leather | Kenwood DNX6960 Performance: Kyowa KR206 17" Black Chrome Lips | Tanabe Sustec Pro NF | Strut Tower Bar Audio: Infinity 6020CS Front | Kappa 62.7i Rear | BASS600 Subwoofer | B-Quiet Ultimate Others: LED Interior+License Plate | EV Button Last edited by usbseawolf2000; 09-08-2009 at 05:00 PM. | |||||||||||||||||||||||||||
| | #43 |
Friends: 0 | I'm missing something. First, a caveat. Normal pictures are terrible for showing me steep slopes, the camera view tends to flatten perceptions. The first video claims the hill has a 15-20 degree slope. But the ground lines on two foundations measure out on my display as 16 and 17 %, which convert to between 9 and 10 degrees, much less steep than advertised. Your graph appears to have a rise of about 120 feet in 0.2 mile, a slope of only 11%, or 6.5 degrees. These numbers are not particularly steep. What am I missing? |
| Thanked by: | usbseawolf2000 (09-09-2009) |
| | #44 | |
Friends: 63 | Quote:
The 15-20 degree was my guess when I edited that video and I am surprise I was way off. From what you saw in the video, does it look like 6.5 deg angle hill? | |
| | #45 |
| A Fairly Senior Member Join Date: Jun 2006 Location: Rockville, MD
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 212
Friends: 2 | ![]() Here's a typical Consumption display readout for my area. I took this particular snapshot last night at the end of a 450-mile drive, so the average mpg is higher than my usual commuting average. However, what is typical is the big variations in the 1-minute readings. The 50-plus to 100mpg readings are when I am going downhill while the 35 to under-50 mpg readings are when I am going uphill. It's almost like an inverted pictures of the hills themselves |
| | #46 |
| Junior Member Join Date: Nov 2009 Location: North East PA
My Car: 2010 Prius Model: III Package: N/A Thanks: 0
Friends: 0 | Hi all, First post! Anyways, I am still on my first tank of gas (just bought the car 11/9/09) and have a "lifetime" average of 46 mpg. I thin that is somewhat typical for what I drive in a day. 55 mile commute to work on a 1000 ft difference (Start high and go low, then reverse it back home)... To work I average 51.3 mpg. To home I average about 43. My total average is about 46.6. I think it will get better once the car/motor is broken in more. The hills and mountains on the PA interstates is what kills the mpg. |
| | #47 |
| Member Join Date: Aug 2009 Location: Nevada
My Car: 2010 Prius Model: II Package: No Package Thanks: 0
Friends: 0 | I've done a bunch of round trips in my 2010 of 300-400 miles. The first 70ish miles are pretty much downhill - from 10,000 feet to sea level. Over this first part I tend to get about 92-93 MPG. By the time I hit 150-200 miles, I'm down to about 65 MPG and then into the mid 50's on the return trip before I start back up the hill. By the time I'm home I've averaged 52-53 MPG over the entire distance. This is about the same MPG I get just driving around town without a lot of concern about driving style - but still taking opportunities to make the instantaneous gauge hit 100 when possible. So my experience is in the end it all just seems to average out to about the same thing. |
| climb, downhill, gas mileage, hills, uphill |
| Uphill or downhill? | lamontcranston | Gen III 2010 Prius Fuel Economy | 4 | 08-24-2009 02:38 PM |
| 2" Makes A Big Difference | StevieB | Gen III 2010 Prius Main Forum | 28 | 07-11-2009 11:39 PM |
| uphill vs downhill | arnoutterschure | Gen II Prius Technical Discussion | 6 | 11-08-2007 01:54 PM |
| Biggest difference between MFD and calculcated MPG | philwojo | Gen II Prius Fuel Economy | 1 | 07-06-2006 12:49 PM |
| First Oil change makes BIG MPG difference! | duffetta | Gen II Prius Fuel Economy | 2 | 06-29-2005 12:15 PM |
