Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010 Prius Fuel Economy
This is a discussion on MPG guage updated? within the Gen III 2010 Prius Fuel Economy forums, part of the Gen III (2010+) Toyota Prius Forums category; Is there a TSB on MPG/ODO deviation. I assume they would not jack with MPH. ScanGauge is close enough for ...
MPG guage updated?
Old 11-02-2009, 12:58 PM   #11
hotbrass
hotbrass's Avatar
Default Re: MPG guage updated?
ScanGauge is close enough for me. I also do the calculation every time I fill up. None of the three match or even come close all the time. Mostly the SG and calculation are the closest.
hotbrass is offline
Old 11-02-2009, 06:10 PM   #12
a64pilot
It's not "broke", they aren't going to "fix" it, it works exactly as intended, and I bet 95% of owners aren't smart enough to know any better.
a64pilot is offline
Old 11-02-2009, 06:26 PM   #13
ALS
You hit the nail on the head with that statement.
ALS is offline
Old 11-03-2009, 09:49 AM   #14
hotbrass
hotbrass's Avatar
Of course its not broke. Its just wrong. If the gas gauge was calibrated incorrectly, it would not be broken, just wrong. I bet they would fix that, well, maybe not.
In software, it is called an "undocumented feature."
hotbrass is offline
Old 11-17-2009, 01:16 PM   #15
raysprius
Model: II
July '09 manufacture date and MPG gauge consistently 1 - 3 mpg high relative to fill-up calculations. Comments on Fuelly.com indicate this is common. Calculations and MPG gauge should use the same distance data so that does not explain the difference. Measuring accurate fuel flow is an inexact science which requires fuel specific gravity, temperature, flow correction adjustments, etc., etc., etc. I imagine the flow meters used on cars are cheap and inherently inacurate (my BMW's MPG gauge is also 1 - 3 mpg high). While the gauges are not accurate they are useful as relative indicators of fuel usage which is probably all they were intended for.
raysprius is offline
Old 11-17-2009, 04:50 PM   #16
codybigdog123
I now have over 2,700 miles on my GenIII. I fill up once a week, every week since taking delivery in August. Every week the difference between the measured and computer generated MPG is 2-3 MPG, with the measured value always being lower, but always higher than the combined EPA number of 50 MPG.
I now have a high degree of confidence that when the diplay says I'm getting 54 MPG, I'm probably getting closer to 51 or 52 MPG. As stated above, there are errors associated with both the measured and displayed MPG figures. So what? Is this really a big deal?
codybigdog123 is offline
guage, mpg, updated
MPG guage accuracy alfon Gen III 2010 Prius Fuel Economy 24 07-02-2009 07:07 PM
mpg guage? fgp Gen III 2010 Prius Main Forum 7 06-22-2009 05:57 PM
Gas Guage problems? cary1952 Gen II Prius Main Forum 4 12-27-2006 03:18 PM
Gas Guage Christine.Anderson Gen II Prius Technical Discussion 3 07-06-2006 11:37 AM
FLASHING GAS GUAGE Eric Gen II Prius Modifications 0 12-29-2004 11:31 AM
