Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010 Prius Fuel Economy
This is a discussion on Got better mpg by driving without thinking within the Gen III 2010 Prius Fuel Economy forums, part of the Gen III (2010+) Toyota Prius Forums category; yeah! i just got 46.7 mpg on my last tankful - with touring rims and bridgestone G017 potenza's. accelerate, lift ...
Old 11-07-2009, 08:54 AM   #11
Genoz World
ZEN-style living
Genoz World's Avatar
Friends: 17
Default Re: Got better mpg by driving without thinking
yeah! i just got 46.7 mpg on my last tankful - with touring rims and bridgestone G017 potenza's. accelerate, lift and chill at the speed limit. at optimal connection to your car, my best advice is to "FEEL" the battery,,,,,,,,a slight throttle action will cause the car to surge a bit, that's the battery, make the most of it without the ICE activating.
do all this and keep a "SAFE" eye on the consumption screen.
Genoz World is offline
Old 11-07-2009, 09:05 AM   #12
Jim05
Occasional Quasi-Hypermiler
Jim05's Avatar
Package: Navigation
Originally Posted by wfolta View Post
One issue is that when you first get the car, you think you know what's best and you're mistaken.
You think since jack-rabbit starts are bad, turtle-slow must be good. You think that if you keep the meters in the proper range 100% of the time, you'll get better mileage than if you anticipate -- something the meters cannot do -- and go out of the "proper" range. You might think that regenerative braking is magic, so use it a lot: it's "free" power. You might see that you're getting 100 MPG+ in EV mode, so use EV mode as much as possible... etc, etc.
I certainly fell for a few of these. The point is, the car is smarter than us when we're operating out of misunderstanding, but we're smarter than the car when we do the human part of the equation: anticipation.
A second issue is that the car naturally gets better mileage throughout the break-in period, so even if you did exactly the same things on the same routes, you'd end up with 5 MPG more after 1500 miles than when you first got the car.
In my mind, the people that get the worst mileage are: 1) those that figure they know how a hybrid works, but are wrong, 2) those that drive like maniacs and call anything else "blue-haired old lady driving", and 3) those who live in a geographical region/climate/culture that's stacked against good mileage to begin with. I fell into category 1 at first, but think I've improved.
Actually, I have gotten more casual about mileage and have played around with different ideas, and my mileage has slipped a bit over time, from my high point.
Hear, hear...All things in moderation. I've also found that anticipation yields the most rewarding results followed quickly (equally?) by conservative speed.
Jim05 is offline
Old 11-07-2009, 09:35 AM   #13
JBar
Model: V
Package: Adv. Technology
Originally Posted by hptsang View Post
I just got the my Prius 3 for less than two weeks. I had been driving by looking at the Eco bar and try not to step too hard and glide as much as possible. I barely can get up to 50 mpg by driving with turtle speed. This morning I turn the display off and drive it like how I drove my BMW 3 series and I ended up with 53 mpg drving from cold start engine. I really think the computer of the car will get you the best mpg for you without thinking too much while driving.
I own a 2010 Prius with Nav and Advanced Technology Package. Drive 40 miles to work north of Alexandria, Virginia using 495 Beltway and Baltimore-Washington Parkway. The ATM has a sensor above mirror which senses (left and right) where your car is on the road and Prius helps you steer the car/sounds alarm if you're far from center lane.
ATM has a (InfraRed ?) sensor at front of the car which detects (driver adjustable) distance to car ahead and relative velocity between car ahead. I Set Cruise Control 10-15 MPG above traffic speed and rarely touch the brake or accelerator while driving 40 miles. I generally drive faster going to work and achieve 46-50 MPG. Coming home is much slower, average 45 mgh, and achieve 51-54 MPG.
Note: 2010 Prius User Manual and Prius Repair Manual are both incorrect at not mentioning that if car is in Brake mode (and has not had drive lever moved to Drive) you cannot Set Cruise Control.
JBar is offline
Old 11-07-2009, 11:32 AM   #14
RodJo
RodJo's Avatar
Model: V
Originally Posted by Tideland Prius View Post
Depending on the grade, you might not have the engine in its optimal power band, that's all I'm saying.
Normal as in none of the buttons activated. (so not eco or pwr). I guess "straining" wasn't the best word. But either way, it'd be nice to get the engine into its sweet spot to better climb the hill, wouldn't it? For this steep mountain climb up the coast mountains, I'd rather have it in PWR mode and let the engine rev freely then keep it in ECO mode (and have the computer restrict rpm)
I thought all the modes just modify the throttle response. And as far as I can tell that seems to be true. In other words, you wouldn't get more power from the car in PWR mode than in ECO mode. It just feels that way because you don't have to press as hard on the accelerator pedal.
RodJo is offline
driving, mpg, thinking
Thinking of buying a Prius: Driving School DrivingInstructor Newbie Forum 13 08-07-2009 09:38 AM
Well i was thinking. Sandy Gen III 2010 Prius Main Forum 6 05-08-2009 06:11 PM
Driving an SUV is less expensive than driving a hybrid car suvdrvr Gen II Prius Main Forum 40 09-20-2008 05:33 PM
Driving drunk is illegal, shouldn't driving with cell phones also be? burritos Fred's House of Pancakes 69 02-25-2007 12:54 AM
Does driving a prius or hybrid absolve you of the sins of driving through a drive-thru? burritos Gen II Prius Fuel Economy 22 08-27-2006 04:15 PM
