Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010 Prius Fuel Economy
This is a discussion on DO GEN III SOLAR PANELS HELP MPGs? within the Gen III 2010 Prius Fuel Economy forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by qbee42 The solar panels are mostly a gimmick. It's a fun gimmick, which I personally like, but ...
LinkBack (2) Thread Tools
Old 11-04-2009, 10:04 AM   #11
yadax3
Prius Admirer
yadax3's Avatar
Default Re: DO GEN III SOLAR PANELS HELP MPGs?
The solar panels are mostly a gimmick. It's a fun gimmick, which I personally like, but you would have a hard time justifying them on any rational basis.
I actually agree with this but I love the moon roof.
yadax3 is offline
Old 11-04-2009, 10:07 AM   #12
That's okay. If we had to justify everything life would be pretty boring.
Old 11-04-2009, 04:18 PM   #13
dogllama
dogllama's Avatar
I always forget about the panels until i come back to my car on a particularly hot day and think, "the car is not blazingly hot...sweet!"
i haven't had great luck with MPG even driving conservatively, but i don't know to what extent the solar panel/moon roof attributes to it. I like the look, i like the functionality and think it's only a gimmick on cloudy days....
dogllama is offline
Old 11-04-2009, 06:09 PM   #14
HTMLSpinnr
Gen III Forums Moderator
HTMLSpinnr's Avatar
Friends: 18
My gut feeling is that the 62lbs of extra weight offset any minimal A/C load reduction at startup. If you use Remote A/C, you're also borrowing energy that must be repaid later as well.
When attempting to cool a hot car, the engine is also in it's warm-up phase, which is a less efficient stage. Depending on your A/C setting, the A/C may not need to run at full blast (or near it in ECO mode) for quite as long, and that's where you'd likely see the economy boost.
What I'm finding now in AZ is that it's still warm enough to heat the interior, but the sun is too far to the south to run the panels at peak efficency. They're also only usable from about 10am to 2-3pm, at which point the fan cycles intermittently w/ the lovely groaning of the motor starting/stopping (DC brushless). I'd like to see an ECU change to allow a lower speed vs. cycling.
Also worth noting, it's generally cool enough outside for me to turn off A/C and open the roof/crack open the rear windows. The additional drag may offset any solar panel savings early on as well.
Rick Johnson - Prius Expert/Gen III Forums Moderator
His: Gen III 2010 Prius - Blizzard Pearl Prius IV w/ Solar - 6.3k miles - (First in SW Region!) - 2010 Photos - Mods: Curt Hitch, Toyota Premium Horn, Illuminated Door Sills
Hers: Gen II 2004 - Tideland Green Pearl #9 - 117.6K miles - Mods: Bridgestone Ecopia Tires, Homemade mesh foglamp grills
Past: Gen I 2002 - Blue Moon Pearl - Mods: Costal hitch
I am not employed by Toyota, and the opinions expressed by me as a Prius Expert are not those of Toyota.
HTMLSpinnr is offline
Old 11-04-2009, 06:11 PM   #15
austingreen
My Car: 2010 Prius On Order
I'd really like one, but don't want the nav system that you have to buy to get it. By forcing this toyota has moved it from a nice to have, to a slimy sales gimmick to sell overpriced and quickly outdated nav systems.
I have to agree with the bulk of people, this should not change mpg very much, but living in a very hot place it would be nice to have a cooler car to get into. So not a gimmick, but really not a usefull package. I'd love a hybrid that plugs in and has fans in its sunroof that doesn't require needless nav packages. I'm sure the solar panels are a gimmick to distract us from the fact toyota won't sell us a plug in for a while.
austingreen is offline
Old 11-04-2009, 07:11 PM   #16
yadax3
Prius Admirer
yadax3's Avatar
I should probably qualify my previous response by saying I don't really think the solar panels are just a gimmick but I do think their impact is minimal, at least in my light-colored car.
This Summer I honestly couldn't tell whether the solar panel had been working until one day when I wanted to sit in my car and check e-mail before going into a business meeting. (BTW I think I read somewhere you shouldn't do this) In any case, the solar ventilation system kicked in after a couple of minutes and it did push the hot air around but it doesn't cool it so I became pretty uncomfortable and didn't sit there very long. That said, if I had it to do all over again I would still buy the solar package because, as I said before, the moonroof is awesome.
2007 Prius Pkg II - Silver Metallic
2010 Prius Pkg IV - Blizzard Pearl
yadax3 is offline
Old 11-05-2009, 04:11 PM   #17
2010_Prius_Owner
2010_Prius_Owner's Avatar
Package: Navigation
The solar package will have no real impact in increasing mileage in itself, it only powers fans that bring draw air out of the vehicle. If a non solar car was parked in the summer with windows down, the interior temp would be similar. So saving fuel by not running AC is not a real point. I not having solar may choose to roll down the windows and not run the AC. Compare weight of the solar package vehicle vs one without and that could have a small impact.
We are talking about vehicle that get between 48 to 62 mpg depending on many factors, mainly how you drive. Other factors are tire inflation, where you drive, are you running heat or AC or non, are Windows down or up and yes the temperature outside can effect temp of battery and effect efficiency.
How you drive and tire inflation will have the greatest impact on you getting the best possible mpg at any given time.
2010_Prius_Owner is offline
Old 11-06-2009, 08:10 AM   #18
richsc
Package: Navigation
I still think the solar panels could be put to other good uses, such as warming the engine on cold days, etc, which could mean they'd be useful without a moon roof, but they'll have to be more efficient. Looks like 40% solar efficiency is happening in the lab at the moment.
richsc is offline
Old 11-06-2009, 10:29 AM   #19
a64pilot
The solar panels just don't make enough power to be useful for much, forget heating anything with them or charging anything really. You could trickle charge the 12V battery I'm sure, but that's not very useful is it?
a64pilot is offline
mpg's, solar package, solar panels
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-fuel-economy/71624-do-gen-iii-solar-panels-help-mpgs.html
Solar Panel This thread Refback 11-04-2009 11:00 AM
DO GEN III SOLAR PANELS HELP MPGs? - PriusChat Forums This thread Refback 11-04-2009 03:04 AM
Solar Panels and PHEVs boulder_bum Environmental Discussion 56 11-02-2009 10:39 PM
Help w/ solar panels SSimon Environmental Discussion 21 07-16-2008 08:37 PM
Solar Panels h2photo Gen II Prius Modifications 5 06-01-2007 08:12 AM
Solar Panels material_claw Gen II Prius Modifications 18 07-09-2006 10:04 PM
Solar Panels??? politically corrupt Gen II Prius Modifications 2 01-16-2006 10:06 AM
