This is a discussion on Dealer says lithium battery available in November within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by Danny Even when the Plug-In is available, the plan is to offer the Lithium Ion battery in ...
Old 01-16-2009, 06:37 PM   #11
miscrms
Plug Envious Member
Default Re: Dealer says lithium battery available in November
Originally Posted by Danny View Post
Even when the Plug-In is available, the plan is to offer the Lithium Ion battery in the plug-in and keep the NiMH in the standard Prius. There was a strong hint that by the time they would replace the NiMH with the Lithium Ion battery they would be ready to launch an even more advanced technology.
That doesn't surprise me much. There is very little advantage to Li-ion over NimH in a standard hybrid. Panasonic EVs NimH cells are pretty impressive. They put out a lot more Amps per Amp hour than most Li-ion would survive. We know output can be over 100A on full acceleration, from a 6.5Ah battery. Thats a routine 15C+ discharge! Many Li-ion are happiest around 3C, some can do 10C for short bursts. Li-ion will cut weight per Wh in half, but as the Prius battery modules only weigh ~60lbs, that wouldn't buy much of anything. Makes it hard to justify the 2x cost increase. You could also double the battery capacity for the same weight, but now you've 4x'd the cost, and the effect on mileage will probably still be negligible. The DOE ran a first gen Prius to 160k miles and found that even though its older style batteries were down to almost 50% capacity, there was no noticible impact on mileage. Similarly early gen2 hackers figured out how to put a second stock pack in a Prius, doubling the battery capacity and also got almost no improvement in mileage. The mileage performance of a standard HEV is just not that strong a function of battery size provided the battery capacity is much greater than the amount of energy stored/released in a standard deceleration/acceleration event, which in the prius case it is.
I know most folks on here know this, as its been discussed a lot, but I think it bears repeating from time to time as there is a common public perception that Li-ion is vastly superior in all things and some kind of magic answer to all our problems. Li-ion becomes much more important for PHEVs, as battery size and weight becomes more of an issue. Larger NimH are also not available due to the Cobasys patent coverage, and building a PHEV pack out of smaller NimH cells get prohibitively expensive and complicated.
Rob
miscrms is offline
Old 01-17-2009, 12:47 AM   #12
Fibb222
Fibb222's Avatar
Rechargable Zinc-Air if I'm not mistaken...
Fibb222 is offline
Old 01-17-2009, 06:53 PM   #13
darelldd
Prius is our Gas Guzzler
darelldd's Avatar
That's what I'm talkin' about.
darelldd is offline
Old 01-17-2009, 07:21 PM   #14
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
Sounds good to me but I'd like to get a Prius before it becomes as expensive as a Lexus =P
Tideland Prius is offline
battery, dealer, lithium, november
Lithium Ion Battery Discussion jonathanrohr Prius and Hybrid News 3 08-06-2007 04:23 PM
New Lithium-Ion Battery Recharges in 1 Minute Ryomatic Prius and Hybrid News 0 03-30-2005 11:34 PM
Toshiba's New Rechargeable Lithium-Ion Battery NuShrike Gen II Prius Audio and Electronics 7 03-30-2005 12:21 PM
breakthrough in Lithium Ion battery Sufferin' Prius Envy Prius and Hybrid News 10 02-24-2005 09:24 AM
