This is a discussion on A more quiet ride! within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Thanks to one of the other members, I was able to download the May 2008 European ratings for all vehicles. ...
A more quiet ride!
Old 03-05-2009, 07:45 AM   #11
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 20
Default Re: A more quiet ride!
Thanks to one of the other members, I was able to download the May 2008 European ratings for all vehicles. This includes the sound level as well as:
Manufacturer Model Description Transmission Engine Capacity Fuel Type Metric Urban (Cold) Metric Extra-Urban Metric Combined Imperial Urban (Cold) Imperial Extra-Urban Imperial Combined CO2 g/km Fuel Cost 12000 Miles Noise Level dB(A) Emissions CO Emissions HC Emissions NOx Emissions HC+NOx Emissions Particulates
The Prius is in the top 151 of 3293 vehicles at 69 dB. The measured sound levels for all vehicles ranged from 66.0 to 77.0 dB. As others have pointed out, we hear the engine at higher power settings. But there is one other noise source, tire noise on some cement highways.
When I attended HybridFest last year, I noticed that many of the Wisconsin and Illinois highways caused unusually loud, tire noise, compared to the roads I ride further South. Sound deadening under the floor would help.
Part of the problem with the NHW11 that led to some sound deadening efforts may have been the engine noise contrast. Up until about 3,000 rpm, my car quietly coasts. But above 3,000 rpm, the sound level is more noticable.
A hybrid specific web site.
bwilson4web is offline
Old 03-05-2009, 08:37 AM   #12
fredthepostman
fredthepostman's Avatar
My Car: Prius On Order
Friends: 7
Originally Posted by donee View Post
Hi Fred,
The Prius is so quiet, as is (except for full throttle accellleration, or up steep hills), that the sound deadening is really just for isolating the noise of other vehicles, and the occaisional pot hole. On smooth pavement, with no other cars around, cruising, its very quiet.
The people who have added sound deading have done it primarily to avoid secondary excitation of the car doors and floors in response to high powered audio systems.
Thanks! I would think that with the larger engine that would run on lower rpm's and the extra insulation , the end result would be a nice improvement.
fredthepostman is offline
Old 03-05-2009, 08:42 AM   #13
Road noise is the biggest offender for me. My Prius is better with Micheline tires, but still you get a lot of tire noise on some roads. Some of our highways have micro groves, and they make the tires hum and howl. On a smooth road my 2006 Prius is unbelievably quiet.
Old 03-05-2009, 09:50 AM   #14
spwolf
another problem is that with absence of engine noise, other noises are amplified.
i applied 3M noise absorbtion tape to my prius doors for lower noise, and indeed road/tire noise was lower which amplified engine noise and actually made it worse for me, IMHO :-)
spwolf is offline
Old 03-05-2009, 10:46 AM   #15
SW03ES
SW03ES's Avatar
The Prius is quiet when its on stealth, but the engine is very harsh sounding and feeling, and the CVT causes that engine to drone under any type of acceleration load.
The car also lets in a lot of road noise. For instance on the Prius and the Lexus I am running the same tires, the Prius has far, far more road noise.
I looked at the chart, those dBA levels seem high to me across all cars...for instance they have the Lexus GS as quieter than the LS, which for anyone who has ever driven the two knows is not the case...
They also have the BMW 1 series quieter than the 7 series...
Steve
2004 Tideland #9
2003 Lexus ES300
SW03ES is offline
Old 03-05-2009, 12:50 PM   #16
spwolf
they are testing in lab conditions... so objective results.
what companies do right now is have "bad" and "good" noises.. good ones are supposed to drain out bad ones.
Because hybrids have much lower droning noises than normal cars, toyota introduced new system on japanese crown hybrid that uses speakers to input droning noise that cancels out "bad" noises.
I am pretty sure new prius will be quieter than old one.
spwolf is offline
Old 03-05-2009, 07:29 PM   #17
donee
Hi Bob Wilson,
You probably did not get a chance to look closely, like 3 inches from, those cement highways in Illinois. They are grooved laterly every inch with a half inch wide groove. Believe me, they are loud in any car.
donee is offline
Old 03-05-2009, 08:15 PM   #18
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
Noise cancellation? The Accord Hybrid had it and so does the RL (Legend)
Agreed. You guys need to drive a Camry Hybrid to know what quiet "sounds" like (more dramatic than driving a Lexus since you kinda expect it to be quiet in a Lexus)
Tideland Prius is offline
quiet, ride
not so quiet prius paberry Gen II Prius Main Forum 3 08-20-2008 09:10 AM
WOW that is QUIET! jewelerdave Fred's House of Pancakes 17 06-28-2007 12:49 AM
Just how quiet is that Prius? JackDodge Gen II Prius Main Forum 19 03-30-2006 12:27 AM
Soundproofing a quiet car galaxee Gen II Prius Main Forum 4 04-04-2005 05:21 PM
Quiet? jeffrey Gen II Prius Main Forum 19 01-30-2004 07:24 PM
