Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010+ Prius Main Forum
[WARNING] Running out of gas (Gen III)
Old 12-20-2011, 08:41 AM   #441
Default Re: [WARNING] Running out of gas (Gen III)
Originally Posted by ramdisk01 View Post
I drive a Prius Gen 3 and believe it is the easiest car I've owned in 40 years to let run out of Gas! Here is why.
Owners manual says fuel capacity 11.9 Gal. Computer says Prius is getting 50 MPG (or similar). Soo I'm thinking 500 miles no sweat. Last Fuel Gauge pip is blinking at 400 miles.
Bob Wilson ran the gen III out of gas intentionally at least twice and found that once the low fuel beep and flashing final bar starts flashing, you have about 2.1 gallons left. I have taken it 90+ miles after the beep on several occasions and have not yet run out of gas.
What was your calculated MPG for the tank when you ran out of gas?
DetPrius is offline
Old 12-20-2011, 10:46 AM   #442
My Car: 2011 Prius
Model: Two
This would be my experience. Yesterday, I got the fuel beep and blink for the first time since owning the car. My commute is basically a mile (maybe 1.5 miles) with two gas stations between home and work, so I just pulled into the Shell and filled up, and it took about 9.2gallons to fill up.
My previous car, a 2007 Civic Hybrid, had about 3 gallons left in the tank when the fuel light would come on, so this is pretty much what I'm used to.
I have noticed that the car's displayed trip mpg seems to be more off the mark (it's over estimating) now that it's gotten colder. Granted, I haven't really owned the car in "hot" weather yet (bought it the last day of October), but it seemed to be a bit more accurate with the slightly milder weather a few weeks ago.
teiresias is online now
Old 12-20-2011, 01:15 PM   #443
My Car: 2012 Prius
Model: Three
I drive a Prius Gen 3 and believe it is the easiest car I've owned in 40 years to let run out of Gas! ...
My easiest car to run out of gas in, was 'my' first car, back in the days of no idiot lights or buzzers a bit less than 40 years ago. It did run out with the needle still above 'E'.
This was not long after my parents ribbed me about being concerned about fuel range in their car with the needle actually on E.
On this score, this Prius is really no different than any of my cars built in the past 30 years.
fuzzy1 is offline
Old 12-20-2011, 05:12 PM   #444
pakitt's Avatar
Package: Premium (Europe)
Well, at least the Prius *does* sound, well *before* you are dry...
pakitt is offline
Old 12-22-2011, 08:01 AM   #445
Model: Two
My first vehicle, a 1979 K5 Blazer, was so unpredictable, you could run out of gas with the gauge at 1/4. I ran out of gas at least 2-3 times with that, once in my Z28, twice in my 2G Prius, and my wife once in the 2G Prius (one of my times was her fault, she took my car because she was low on gas). I haven't bothered risking it in the 3G Prius, but I am curious about how far it COULD be pushed. I put in 9.5 gallons or so this morning, with 50 miles left on the range gauge.
I only bothered to read through about 15 pages, and it just seems like people agree to disagree. Having personally ran out of gas on the freeway at 65, I loved the fact that I could limp to the gas station. I made it just as my battery bars had turned purple.
I've had to walk to a gas station while running out once (died 1/4 mile from the station, would not go any further on the battery).
Anyway, my 2 cents - the limp mode is certainly a cool feature, but I define it as a necessity when you have an unpredictable fuel tank/bladder. If the 3G has a more accurate gauge, I see no point in having limp mode as it should become harder to run out of gas.
When I ran out of gas in the 2G, it was with about 480 miles on the trip meter, and an economy of about 48 MPG. I was POSITIVE I should have been able to go at least another 45 miles, but sure enough I ran out of gas. The culprit? A wife who doesn't pay attention when she fills up the tank, and if the pump stops, she must be done fueling up. I always try to make sure that I am filling up as much as the car calculates I have burned, and if it takes more than that, fine.
If anything, if I had to pick something that frustrates me, it would be the fuel bladder in the 2G.
Erik Aalto is offline
Old 04-18-2012, 02:28 PM   #446
My Car: 2012 Prius
Model: Three
Package: Moonroof Upgrade (Canada)
I actually ran out of gas when picking up my mother-in-law at the airport. I totally thought I had more gas than I thought when it turns out my other half used the car and didn't tell me, and didn't bother filling up!
But yes, my habit is that when the gas gauge beeps, I'm at a gas station within reason.
My mother, used to fill her '86 Ford Escort whenever it hit quarter of a tank.
mathan is offline
Old 04-18-2012, 03:10 PM   #447
My Car: 2012 Prius
Model: Five
Package: Adv. Technology
Originally Posted by bwilson4web View Post
I can buy a new traction battery and have no problem with being put in "EV" mode. But the car would not shift into "D" nor respond to "EV." Compared to the NHW20 and NHW11, this means a valuable safety feature has been lost.
Has anyone done any recent experiments on the 2012's? I'm curious how crippled my car would be if it runs out of fuel. Seems silly that the car would potentially stop dead even if there is a perfectly good traction battery with more than enough charge to pull the car off the road...
Rªzª is offline
Old 04-18-2012, 03:14 PM   #448
My Car: 2012 Prius
Model: Five
So how bad was it when you ran out? Was the car completely crippled?
Rªzª is offline
Old 04-18-2012, 04:27 PM   #449
My Car: 2012 Prius
Model: Three
This was a Gen 2 2009 rather than a Gen 3 - I literally ran out driving to the airport and ended up driving up to the gate to get my parking pass, and pulled into a spot just as the electric went purple. I was s******* myself.
I have no plans on running out in my Gen 3 2012.
mathan is offline
Old 04-18-2012, 04:36 PM   #450
The car completely crippled?? Didn't you read, he was picking up his mother-in-law. It was mathan that suffered the effects of running out of gas.
sub3marathonman is offline
gas, running, warning
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/64211-warning-running-out-gas-gen-iii.html
Capacit du rservoir et Autonomie - Page 2 - Forum Prius Touring Club This thread Refback 04-26-2012 02:17 AM
Capacit du rservoir et Autonomie - Page 2 - Forum Prius Touring Club This thread Refback 04-25-2012 04:53 PM
Capacit du rservoir et Autonomie - Page 2 - Forum Prius Touring Club This thread Refback 04-25-2012 02:53 PM
P3: Benzinmenge bei Reserve-Warnung - PRIUSforum This thread Refback 04-07-2012 01:56 PM
P3: Benzinmenge bei Reserve-Warnung - PRIUSforum This thread Refback 10-21-2011 07:56 AM
Indicador de combustível - Prius-PT This thread Refback 09-12-2010 11:45 AM
Gen III 2010 Prius Main Forum - PriusChat Forums This thread Refback 08-31-2010 10:47 PM
Running out of OIL ?? Charles Suitt Fred's House of Pancakes 59 01-01-2010 10:54 PM
Master Warning, ABS, (!), and Hybrid Vehicle Warning icon Patrick Wong Gen II Prius Care, Maintenance and Troubleshooting 42 07-04-2009 01:32 PM
Should I keep running e85 sithlord_master Gen II Prius Main Forum 54 06-28-2009 02:28 PM
Running in and MPG... Dozzer Gen II Prius Fuel Economy 4 09-11-2008 03:30 PM
Running Out of Gas! Ichabod Gen II Prius Main Forum 25 03-22-2007 10:20 PM
