| This is a discussion on Insert DVD Navigation Disk within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; When a new version of the NavDVD is inserted, it takes some time (minutes) for the new software (or whatever) ... |
| | #31 |
| Senior Member Join Date: Aug 2009 Location: Orange County, CA
My Car: 2010 Prius Model: III Package: Navigation Thanks: 0
Friends: 2 | When a new version of the NavDVD is inserted, it takes some time (minutes) for the new software (or whatever) to be read into the internal (probably flash) memory. Sounds like either: the DVD player (reader) is having trouble reading the DVD (most likely), or the "internal" memory has gotten messed up (less likely). The two most common reasons for the DVD not reading are: The DVD is scratched (possibly by the read head itself) or dirty (easy to remove the DVD and check), or the read-lens is dirty and needs cleaning (harder to do). The third reason is the use of too much "grease" on the moving parts of the drive, which gets to "stiff" over time, and at lower temperatures. Unfortunately, disassembly of the drive (and removal of 99% of the grease) can be very difficult and time-consuming. Last edited by garygid; 10-30-2009 at 10:53 PM. |
| | #32 | |
| A Fairly Senior Member Join Date: Jun 2006 Location: Rockville, MD
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 201
Friends: 2 | Quote:
Whenever it happens and eventually reboots, the reboot takes several minutes. What's particularly annoying, apart loss of use durng the error and reboot period, is that each time it reboots, I lose all my nav/voice settings.
__________________ 2010 Prius IV with solar package Winter Grey with Misty Grey interior and dark grey floormats Took Delivery 7/31/2009 Previous car: 2006 Prius Package III, Classic Silver Metallic | |
| | #33 | |
Friends: 2 | Quote:
| | #34 |
Friends: 2 | Toyota called me today and they told me they are still working on the case but they hadn't heard of this issue before. I told them that I have heard of three other people who have had the problem., If you are experiencing this problem, please call Toyota's 800 number so that they know there is more than one person having this issue. It happened again yesterday. This time, it didn't just freeze. It was flashing like it was starting to reboot. Then it actually started a reboot but looped back into error mode. Eventually, it did reboot, but took 5 or 10 minutes. |
| | #35 |
| Junior Member Join Date: Jul 2009 Location: Delaware
My Car: 2010 Prius Model: III Package: Solar Roof Thanks: 7
Friends: 0 | hello, I have a one month old pkg III with nav and solar that has been acting up lately, but I do not have the DVD. Am I missing something? How do I chk my version of NAV? Thanks Karen |
| | #36 |
Friends: 0 | guys, To those who have this problem, it usually is caused by moisture which has accumulated in early morning. Those who park their cars outside are more likely to face this issue. It is certainly not owners' fault. Toyota might have a batch of NAVI units that do not have sufficient design consideration for moisture, which accumulates on disc or len of laser reading head. Try this. - put some lime desiccant packs around the head unit See if that helps. If yes, you have found the cause. Tell Toyota about it. You should demand for a new head unit AFTER they find a fix. My gen-II had that happen once only. Never happened again. However, my Prius is always parked inside garage overnight.
__________________ 2005' Tideland Prius (Dec, 2004) Mods Done: body-side moldings, wood dash kit, rear bumper applique, ultrasound backup sensors, backup camera, signal mirrors, BT stiffening plate, 205/60R15 tires, leather-trim interior, all-weather mats, shark-fin antenna |
| | #37 | |
| High Fiber Member Join Date: Jun 2005 Location: South OC So Cal & the Flathead Valley MT
My Car: 2004 Prius Model: Package: #9 Thanks: 15
Friends: 12 | Quote:
| | #38 |
| Senior Member Join Date: Jan 2006 Location: Amsterdam, Netherlands
My Car: 2006 Prius Model: Package: B Thanks: 0
Friends: 0 | sounds like an intermittent power failure, that causes the nav-unit to loose its settings and need to load the sofware from the dvd again. I don't think it's a problem with the dvd |
| | #39 | |
Friends: 2 | Quote:
The instructions for checking the version are in the navigation system owners manual. I think it's the Info button. | |
| | #40 | |
Friends: 2 | Quote:
Recently, it's been quite cold first thing in the morning (low to mid-thirties, but not below freezing) and I haven't had a problem. | |
| disk, dvd, insert, navigation |
| Navigation Disk Update | Metro | Gen II Prius Audio and Electronics | 166 | 11-17-2009 04:55 PM |
| Navigation Disk, 2006 Prius, Version & Where to buy | Steve-in-NJ | Gen II Prius Main Forum | 1 | 12-16-2008 02:59 PM |
| Error Updating NAV DVD: "please insert correct map disk" | LOLGuy | Gen II Prius Audio and Electronics | 5 | 01-06-2008 09:36 PM |
| Insert Key? | Jeri | Gen II Prius Main Forum | 7 | 02-25-2005 02:55 PM |
| THE NEW NAVIGATION SYSTEM DISK HAS ARRIVED. | Arizona Charlie | Gen II Prius Main Forum | 16 | 12-25-2004 01:43 PM |
