braking in reverse
| | #181 |
| Junior Member Join Date: Dec 2009 Location: NV
My Car: 2010 Prius Model: V Package: Navigation Thanks: 0
Friends: 0 | Hello- I've owned my 2010 Prius V about a month, and I've had this grabby brake problem occur four times. It's really an irritating problem, and I will be sure to relate it to the dealer during servicing. I would tend to agree with other posters here who associate the problem with sitting in the car while it is in the 'accessory on mode' for a while. If you then start the car, and try to back up, that is when it occurs for me. |
| | #182 |
| Senior Member Join Date: May 2007 Location: Morro Bay, CA
My Car: 2012 Prius Plug-in Model: Plug-in Base Package: No Package Thanks: 444
Friends: 1 | OK, it happened to me again today, in Drive not reverse. The car has 6070 miles. We came out from the grocery store so the car had been sitting for 10 minutes or so. Foot on brake, push the pwr button, very slight incline so I kept my foot on the brake but let off just enough to creep forward. I had to stop for a car and that's when it started grabbing. The 'travel' on the pedal came way up and it had the very hard feeling and was impossible to stop without jerking. I just stopped and shut the car off and re-started and all was normal again. Although many have tried, I'll try to replicate the conditions and see if it's repeatable. |
| | #183 |
| Senior Member - Blizzard Pearl Join Date: Aug 2009 Location: Orange County, CA
My Car: 2010 Prius Model: III Package: Navigation Thanks: 0
Friends: 3 | I have had it happen going forward once, and backward about 5 or 6 times in 5000 miles. For me, not associated with accessory mode. In backing, more often when starting to back down a slight incline. But, at least once on the flat. Always just after starting the car. Last time, shifting to N and D then back to R did not "cure" it. |
| | #184 |
| Senior Member Join Date: Oct 2009 Location: toronto, canada
My Car: 2010 Prius Model: N/A Package: Premium (Canada) Thanks: 92
Friends: 0 | I have been keeping an eye on this grabby brake problem for a while. My 2010 has 3000 miles+ so it is well broken in. This problem has been occuring since I got the car two months ago. It has nothing with running accessory mode prior to starting or what so ever. It just happens when I back out the car from the garage. Even thought it doesn't happen every time but it is becoming a concern for me. I hope Toyota notice this fault through this forum and issue a fix for it soon. |
| | #185 |
| Junior Member Join Date: Oct 2009 Location: san jose
My Car: 2010 Prius Model: II Package: No Package Thanks: 5
Friends: 0 | " I hope Toyota notice this fault through this forum and issue a fix for it soon." Based on how they've handled the current issues, I don't think so. Moreover, with the current recalls going on, for sure they don't need more issues or have time to read this forum (no irony intended). Yes, I have also experienced this issue since I bought the car. It happens randomly, mostly when I pull the car out of the garage. With so many complains in this forum, isn't it time that we, the owners, take action? Personally, I called a few dealers; all of them are not aware of the issue; very curious! I checked the NHTSA site, and there's no defect under investigation for 2010 Prius. Not sure NHTSA complain is a solution, so does anyone have a suggestion for action? |
| | #186 | |
| Senior Member Join Date: Jun 2007
See video: I noticed the problem most often after sitting with the ignition on (listening to the radio at lunch) and then backing out of a parking space, but I cannot reliably reproduce it 100% of the time. | |
| | #187 | |
| Senior Member Join Date: Mar 2006 Location: Devonport, Tasmania
My Car: 2009 Prius Model: N/A Package: I-Tech Thanks: 5
They did not say whether it was the lock-up problem you have had or the brakes letting go over rough slippery ground. Hopefully they will fix both problems. | |
| | #188 | |
| Junior Member Join Date: Jul 2009 Location: Philadelphia
My Car: 2010 Prius Model: V Package: N/A Thanks: 1
I do love that car! | |
| | #189 |
| Senior Member Join Date: Apr 2007 Location: Los Angeles
My Car: 2010 Prius Model: II Package: No Package Thanks: 16
Friends: 0 | I still get the sticky brakes in reverse thing every once in awhile. Not a huge deal, but annoying to turn the car off and I again so I can back up without lurching all over the place...any idea if the propsed fix will have any effect on this? |
| brake, braking, break, effect, recall, reverse, thing |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/65875-braking-in-reverse.html | ||||
| This Car Is Starting To Worry Me! - Toyota Owners Club - Toyota Forum | This thread | Refback | 04-20-2011 06:05 AM | |
| Mi Toyota Prius - Buscandole defectos al Prius 3G - Prius 3G - 2009/2010 | This thread | Refback | 02-03-2011 05:17 PM | |
| Gen III 2010 Prius Main Forum - PriusChat Forums | This thread | Refback | 01-08-2011 04:49 AM | |
| Mi Toyota Prius - Buscandole defectos al Prius 3G - Prius 3G - 2009/2010 | This thread | Refback | 07-29-2010 01:53 AM | |
| Prius Brake Problems ~ PriusChat Forums Confirmed With Test - Letter Sent | Fixing Cars | This thread | Refback | 05-17-2010 09:24 PM | |
| Reverse Beeping | Alnilam | Gen II Prius Main Forum | 55 | 11-21-2011 06:59 AM |
| Max. Speed in Reverse. | ronhowell | Gen III 2010+ Prius Main Forum | 6 | 05-05-2009 05:13 AM |
| ICE Runs in reverse.. | seftonde | Gen II Prius Technical Discussion | 16 | 06-22-2007 11:14 AM |
| 07 reverse | bradysplace | Gen II Prius Main Forum | 9 | 03-15-2007 11:49 PM |
| what happens if you go from neutral to reverse? | stanleyjohn | Gen II Prius Main Forum | 12 | 09-11-2006 12:43 PM |
