| This is a discussion on EV button - what's the point? within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; I use EV to keep the ICE off while I get away from my neighbour's bedroom window when leaving LOL, ... |
| | #11 |
| Senior Member Join Date: May 2009 Location: North Central WV
My Car: 2010 Prius Model: V Package: Navigation Thanks: 5
Friends: 2 | I use EV to keep the ICE off while I get away from my neighbour's bedroom window when leaving LOL, is this what you guys really meant? That's the only real value I can see in it. |
| | #12 |
| Senior Member Join Date: Apr 2009 Location: Southeast Michigan
My Car: 2010 Prius Model: III Package: No Package Thanks: 14
Friends: 0 | Mine also cuts out due to excessive speed at 12 mph with a "full" battery but it only does this when the ICE is cold. Once warmed up, I can always get up to 25 mph before it cuts out. |
| | #13 | |
| Junior Member Join Date: Jun 2009 Location: Southern California
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 13
Regardless of battery charge level, I cannot get the car into EV mode (via the button) until after the car is driven for a minute or two or more. | |
| | #14 |
| Senior Member Join Date: Jun 2009 Location: Washington DC
My Car: 2010 Prius Model: III Package: No Package Thanks: 9
Friends: 0 | As people have said, it's a niche use. I mainly think of times on summer vacation when it would have been nice when leaving early or arriving late with lots of tents or open windows around. It's not quite as useful as the old days of V-8's though. I can remember starting cars, like an old-school Chevy Malibu, early in the morning and feeling like the whole world could hear you. |
| | #15 |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 228
Friends: 23 | - moving around underground or enclosed parking lots - moving the car in/out of the garage - moving the car to another parking spot - shutting off the engine on the last stretch home (no need for the engine to keep warm if it's the last run of the night) |
| | #16 |
| Junior Member Join Date: Jul 2009 Location: GA
My Car: 2010 Prius Model: III Package: Base Thanks: 0
Friends: 0 | I was personally very impressed by how powerful it is. I use it to cruise in the neighborhood but most of the time use my foot to do it manually instead of hitting the button. |
| | #17 |
Friends: 2 | In my experience, the EV switch is worth something... but just how much is highly dependent on driver self-discipline and the particular drive/commute route. I installed my EV switch because I just couldn't believe something that seemed so cool could only produce the limited efficiencies that were reported here... call it basic research. I've had the switch installed for more than a year, that is to say through both warm summers and cold winters. Well, everyone was right: the EV switch is not the proverbial FE/MPG "silver bullet." In warmer times when the ICE and catalytic converter warm up in a few minutes, the only use I've found for the EV switch is very short runs imediately after the car is started -- backing out, and immediately a 90 deg turn all at speeds less than 20 MPH. Oh yeah, and the occasional ego-stroking to keep the neighbors in a state of confusion as to whether or not the car is hybrid, or PHEV, or full EV. Evil... but fun! But even here, getting into and staying in EV mode at start-up is not a gimmie. You have only three or four seconds after you hit the Start button to make the transition. So, get all all the little getting-ready-to- drive details out of the way before you hit the Start button. This would include seat belts, parking brake, wiping windows, whatever. In my experience, once you hit the Start button and the Ready light comes on, you have but two or three seconds to engage EV mode AND start the car moving. If you miss this, the HSD will revert to normal operation and the ICE will come on and start the warm-up cycle. Colder months are a wholly different matter. At these times the EV switch can be a major element in recovering MPGs greatly reduced by longer warm-up times/distances. (I do grill blocking, but no block heater in colder months.) A necessary aside: There are so darn many tricks and kinks to getting really good MPGs that I get confused. So I try to distill things to broad "rules" that are applicable in my mostly urban driving environment at Posted Speed Limits, PSL, up to 40 MPH. Some of mine are: * Gas burned when the car is standing still is gas wasted. * Gas burned to maintain speed, at constant velocity, is acceptable but should be minimized consistent with safe driving. * Gas burned to accelerate to PSL, or PSL + a little, is gas well spent as then I can pulse & glide. * Pulse and glide produces ~50 MPGs if the glide is 4 times the distance of the pulse (constant acceleration). Pulse and glide at 6x the pulse distance gets 70+ MPGs. In my experience, this holds more or less true at target speeds between 25 and 40 MPGs. Back to EV use in colder months -- well, cold but not really cold -- lets say 30-45 degF. (One of the necessary conditions to get into EV mode is the HV battery can't be "too cold." Exactly what that means, I'm not sure. But I do know that after an overnight "cold soak" at 30 degF outside temps, the HV battery is "too cold.") The best use of the EV switch/mode is to suppress the HSD trying to keep the ICE turning over and using fuel when the car is at a stop, or to get into a no arrows glide below 34 MPH (Gen II) in EV mode when the HSD won't allow it in the warm-up cycle. But even here this practice is conditional; you have to have above ~110 degF ICE block temps... the ScanGauge is a very useful tool. In summary, Is the EV switch "worth it?" Definitely maybe. Properly executed, I can realize 5-8 MPGs with very careful use of the switch in my 28 mi. round trip commute. For somebody else... I don't know. Also, in colder weather if you want highest FE/MPGs you must drive through the entire ICE warm-up cycle without using the cabin heater. If you use it you divert heat from heating the block and extend the time/distance to fully warmed-up. One benefit of using the EV switch is that in keeping track of all the conditions and details you are distracted from realizing that your feet, hands, nose, and ears are going numb. ![]() As is so often the case, beauty, or in this case usefulness, is strictly in the eye of the beholder. Hope this helps. Last edited by Rokeby; 07-25-2009 at 10:59 PM. |
| button, point |
| What is the point of being at this site when.... | kettledrum | Fred's House of Pancakes | 26 | 08-19-2007 03:51 PM |
| At what point... | beezy | Gen II Prius Main Forum | 28 | 05-19-2006 10:49 AM |
| Cig lighter point? | senectus | Gen II Prius Main Forum | 4 | 02-23-2005 10:51 PM |
| What's the point? | ekc | Gen II Prius Audio and Electronics | 3 | 12-23-2004 11:26 AM |
| Battery SOC, EV Button, and Warranty: point to ponder | jrawles | Gen II Prius Main Forum | 2 | 05-27-2004 10:00 PM |
