| This is a discussion on emergency equipment within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; A can of those temporary "fix a flat" tire inflator/foam things ... (I'm not sure what the limitations are with ... |
emergency equipment
| | #11 | |
| Senior Member Join Date: Feb 2009 Location: Western Washington
My Car: 2010 Prius Model: II Package: No Package Thanks: 23
| | #12 |
| Senior Member Join Date: Jun 2009 Location: New Orleans
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 28
Friends: 5 | |
| | #13 |
| Member Join Date: Jun 2009 Location: Chicago
My Car: 2010 Prius Model: II Package: No Package Thanks: 5
Friends: 0 | I carry an eletric air pump to inflate flat tires. 90% of the flats I have gotten were slow leaks and usually pumping the tires back up will give me a few hours of driving to get my tire fix without ever needing to reach for the spare donut. My pump also has an emergency flasher light that can also be converted to solid white flash light. I use it regularly to check tire pressure with the built in gauge. ![]() I also have a head band flash light, that uses LED. If i put a set of lithium AA batteries in it, it should last about 10 years without needing to change them. When you have to change the tire or do something in the dark, you want both hands to be free and available. ![]() There are new fire extinguishers the size of a can of hair spray. They take up very little room in the trunk. Lastly, a pack of beef jerky. Emergency food or just a snack |
| | #14 |
| Senior Member Join Date: May 2009 Location: New Orleans
My Car: 2010 Prius Model: III Package: N/A Thanks: 5
Friends: 2 | I make sure I'm wearing a comfortable pair of shoes. |
| | #15 | |
Friends: 10 | Quote:
Tom | |
| | #16 |
| Senior Member Join Date: Jan 2009 Location: Chicagoland, IL
My Car: 2010 Prius Model: V Package: Navigation Thanks: 173
Friends: 8 | In Europe (For sure in France), I know that it is required that every driver keep a safety (orange or bright yellow) vest with reflector strips in the vehicle in case of emergency. They have several other required items, but it was the vest that I thought was very smart. They shoudl require that in all cars here too. Only a few bucks, but they may save your life. |
| | #17 |
| Member Join Date: Nov 2006 Location: San Diego
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 4
Friends: 0 | Gorilla power wrench to provide the extra bit of leverage to deal with the awkward positions you'll be in when needing to change a flat tire on the road. Used to carry an automotive fire extinguisher. Can't tell how many times I've been the only one around at work with a long set of jumper cables. |
| | #18 |
| Senior Member Join Date: Jul 2009 Location: Czech Republic, EU
My Car: 2008 Prius Model: N/A Package: Navigation Thanks: 14
Friends: 2 | I carry a first aid kit, four-pound fire extinguisher, wool blanket, reflective triangle, reflective vest, flashlight, jack & wrench to change a wheel, and small emergency spare wheel. Also some spare light bulbs & fuses, and a paint repair kit |
| emergency, equipment |
| Equipment Initials | aljorma | Gen II Prius Main Forum | 3 | 05-23-2008 06:17 PM |
| Key Fob/SmartKey as Exercise Equipment | rufaro | Gen II Prius Main Forum | 3 | 07-20-2006 10:14 PM |
| Using Ham equipment in a Prius | Jeri | Gen II Prius Main Forum | 12 | 02-23-2005 11:07 AM |
| PRIUS EQUIPMENT PACKAGES. | Arizona Charlie | Gen II Prius Main Forum | 1 | 07-01-2004 09:15 AM |
