This is a discussion on More on USB/Safety Connect within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by cpatch This is correct...I bought the kit and had it dealer-installed and the original aux input in ...
Old 08-21-2009, 05:10 PM   #21
Dirk Lerxst
Default Re: More on USB/Safety Connect
Originally Posted by cpatch View Post
This is correct...I bought the kit and had it dealer-installed and the original aux input in the center armrest console is replaced with a new combo USB/aux input as shown in this video:
YouTube - 2010 Prius iPod/USB Navigation Interface Demo
And no, you can't control the iPod directly unless you disconnect from the USB port and plug into the aux port. It's a major shortcoming of the kit, especially considering how unusable the nav interface is.
Thanks for posting that. It initially looked promising in the video, but quickly confirmed my thoughts on how slow and cumbersome this interface is going to be to use. I will admit that it's more elegant than others I've used, and it is faster, but it's still FAR too slow to be safe to be using when you could pick up the Ipod and scroll quickly or, on the Iphone/Touch, flick down to the artist in a second or select the letter of the artist from the alphabet on the right side of the screen. I don't get why the Toyota unit has to be so painfully and dangerously slow. Too bad - so close to right. I'm very, very glad to see the 3mm input is still there, but I really wish I could just turn off headunit control so I could use the USB to both charge and get sound out of my Ipod.
Dirk Lerxst is offline
Old 08-24-2009, 09:33 AM   #22
schaefsn
My Car: 2010 Prius On Order
Package: Navigation
I have a very direct question that I cannot get a straight answer to:
If the USB option is installed by a dealer, you end up with a USB outlet AND a 3.5mm audio aux jack in the console, do both work?
I am seriously considering having the USB installed but would really like an answer to this question to help me make up my mind.
schaefsn is offline
Old 08-24-2009, 11:28 AM   #23
stream
stream's Avatar
Model: V
Package: Navigation
Just to play devil's advocate--if the USB adapter contains both a USB and an aux input, as shown in cpatch's video, why wouldn't they both work?
stream is offline
Old 08-24-2009, 01:17 PM   #24
schaefsn
Package: Navigation
I agree. Despite this common sense answer I have seen posts that seem to suggest that the AUX is disabled when the USB option is installed. I want to make sure that is not the case.
schaefsn is offline
Old 08-24-2009, 01:57 PM   #25
stream
stream's Avatar
Model: V
Package: Navigation
Interesting--I hadn't read that, although with the iPod connector, I've read how the SAT was disabled on some cars (but not on others).
stream is offline
Old 08-24-2009, 02:47 PM   #26
ERiley1
As I understand it, the SAT is disabled with the interface kit seen on the accessories site here: Toyota Prius Accessories which is different from what is being installed. As for whether the AUX still works, I don't know. Even though it does seem like the obvious answer that it should.
ERiley1 is offline
Old 08-24-2009, 03:15 PM   #27
stream
stream's Avatar
Model: V
Package: Navigation
Yes--that's the iPod connector I was referring to.
stream is offline
connect, usb or safety
Safety Connect alj65aedeker Gen III 2010 Prius Main Forum 44 10-16-2009 08:35 PM
USB and Safety Connect Are Almost Here! Prius Team Gen III 2010 Prius Main Forum 234 10-11-2009 11:15 AM
Safety Connect and 2010 prius MattD Gen III 2010 Prius Main Forum 16 08-19-2009 11:18 PM
dear god, when is safety connect going to be available. toyota doesn't even know. poodlemaster Gen III 2010 Prius Main Forum 4 07-18-2009 07:45 AM
Safety Connect IraS Gen III 2010 Prius Main Forum 6 06-19-2009 04:53 PM
