| This is a discussion on Any recommendations for a great tire pressure gauge? within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by MaggieMay Sorry 'bout that Indyking - mine is a squeeze through the wheel cover, but I can ... |
| | #21 | |
| Vem quente que estou fervendo! Join Date: May 2009 Location: Indianapolis
My Car: 2010 Prius Model: III Package: No Package Thanks: 92
Friends: 4 | Quote:
It's OK. The gauge works fine with a little twisting, no problem. Regarding the wheel covers, it appears that just at least one person reported a 5 MPG hit without them but most people agree that if there is any hit at all, it should be around 2-3 MPG. Also, it appears that the impact on MPG is often seen only with highway driving... The impact seems to be negligible with city-only driving… | |
| | #22 |
| Junior Member Join Date: Sep 2009 Location: Central Indiana
My Car: 2010 Prius Model: V Package: Navigation Thanks: 0
Friends: 0 | Can't post the link (under 5) but Longacre racing dot com has some nice and some expensive tire gauges. Purchased the magnum last year with angle chuck. -Bill |
| | #23 | ||
My Car: 2006 Prius Model: Package: #6 Thanks: 18
Friends: 12 | Quote: Quote:
| | #24 |
| Member Join Date: Aug 2009 Location: California
My Car: 2010 Prius Model: III Package: Navigation Thanks: 9
Friends: 0 | I just got my Accu-gage 60psi from getagauge.com. The gauge works great and I don't have to worry about batteries going dead like the digital kind. Really fast shipping, 100% satisfied! |
| | #25 | |
| Senior Member Join Date: Jun 2006 Location: Kansas
My Car: 2010 Prius Model: III Package: No Package Thanks: 20
Thanks! Bryan | |
| | #26 |
Friends: 4 | |
| | #27 |
| Senior Member Join Date: Apr 2009 Location: Gloucester, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 313
Friends: 5 | Bryan - I got the swivel version - like I said earlier, it's tight with the wheel cover, but it works! |
| | #28 |
Friends: 0 | Thank you everyone for the inputs. I guess I still have one more thing to resolve before I order an AccuGauge. I like the idea of being able to add air and bleed it with the gauge hooked up to the tire. However, to do this, it looks like the EZ-Air model by Accugauge is the only model that will allow you to do this. A picture of the EZ-Air can be found by clicking here. Does anyone have this model and can verify that it still fits, or does the plastic hub cap make the fit too tight to use? Also...I assume that the H-series models do not clip on to the tire making them slightly more difficult to use? Thanks again! Bryan
__________________ 2006 Prius - Magnetic Gray - Package 6 2010 Prius - Blizzard Pearl - Package III |
| | #29 |
Friends: 0 | Has anyone tried the EZ-Air version? ^^^ see thread above ^^^ Thanks! Bryan |
| | #30 | |
| jay_man_also Join Date: Jun 2009 Location: Manassas, VA
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 58
Friends: 3 | Quote:
EDIT- so I got off my butt and tried it on a couple of wheels. I had no issue like Indy with leaking air while clamping it on, and it seemed to fit okay, but when I removed it I did notice the wheel cover circle around the valve was marred and pitted a bit. One wheel cover was nicked in a couple of places, and the other in just one, where the edge of the clamp touches the wheel cover. I also noticed that the gauge reads 2 psi higher than my old one, which is similar to the S-series gauges, picture attached. I'll use the new gauge when I fill the spare with the valve extender, but won't be planning on using it on the other tires. I imagine if you got a short set of valve extenders like I had to put on a Scion xB the EZ Air gauge would be just fine. Last edited by jay_man2; 09-11-2009 at 05:28 PM. | |
| The Following User Says Thank You to jay_man2 For This Useful Post: | bps (09-12-2009) |
| gauge, great, pressure, recommendations, tire |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/68404-any-recommendations-great-tire-pressure-gauge.html | ||||
| Gen III 2010 Prius Main Forum - PriusChat Forums | This thread | Refback | 10-08-2009 06:46 PM | |
| Looking for a good digital tire pressure gauge | Aaron | Gen II Prius Care, Maintenance and Troubleshooting | 8 | 04-01-2008 11:57 AM |
| new tire pressure gauge | RobertG | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 08-22-2007 02:15 PM |
| What good tire pressure gauge to buy? | george6233 | Gen II Prius Main Forum | 10 | 08-15-2006 10:09 PM |
| Tire Pressure Gauge Reccomendations | Wynder | Gen II Prius Main Forum | 4 | 12-28-2005 10:42 AM |
| Recommendations on a tire gauge? | acousticbiker | Gen II Prius Main Forum | 3 | 12-28-2005 10:21 AM |
