This is a discussion on 2010 headlight height within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Does anyone know if you can adjust the height of the low beams? I have read the manual cover to ...
Old 09-18-2009, 10:36 PM   #1
Habiru
Model: II
Default 2010 headlight height
Does anyone know if you can adjust the height of the low beams? I have read the manual cover to cover (yeah I am one of those) but I am unable to determine how/if this can be done. If someone knows how could you post a pic of where under the hood I should be looking?
Habiru is offline
Old 09-19-2009, 10:34 PM   #2
Felt
Package: Navigation
Default Re: 2010 headlight height
Yes, the lights can be raised. You cannot raise just the low beam, however. Look under the hood at the right and left light. Between the bulbs a black plastic shape protudes back towards the rear. In the center of the projection is a hex nut (3/8" as I recall). Turning the nut counter clockwise will raise the lights.
Good luck.
Felt is offline
Old 09-21-2009, 01:59 PM   #3
Habiru
Model: II
Thanks for the info I'll give it a look.
Habiru is offline
Old 09-21-2009, 02:10 PM   #4
Keep in mind that this does not change the headlight height, but simply adjusts the alignment.
qbee42 is online now
2010, headlight, height
2010 Prius V Auto LED headlight dbz Newbie Forum 4 08-11-2009 08:47 AM
2010 Prius LED Headlight swap. ScarGo Gen III 2010 Prius Main Forum 23 08-06-2009 11:08 AM
Prius Gen III ride height Metroplex88 Gen III 2010 Prius Main Forum 3 07-23-2009 12:35 AM
HID height adjustment lenjack Gen II Prius Technical Discussion 7 12-14-2008 02:13 PM
Proof of Seat height adjuster in 2010 ScarGo Gen III 2010 Prius Main Forum 15 08-26-2008 05:40 AM
