Hmmm.
Mebbe a little less Mad dog, son?
Originally Posted by RadioMan OK, It has happened several times now. Whenever I put over about 50 lbs of gear in the trunk for a few hours, when I get the gear out, the car remains lop-sided. Yes, it is between 3/4ths and 1.5 inches lower to the ground on the drivers side- measured at the rear of the car. The wheel-well to top-of-tire and the car frame to ground are identical. You can't bounce the Prius like a normal car.
Only after driving it without luggage for a while does it equalize again. As little as a half-inch is visible to the eye. 1 inch looks really bad. Has anyone looked to see if this is happening to them? Help!
Bob in Hot Springs  |
