This is a discussion on Another Bizzare Gen 3 Anomoly within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; OK, this is a weird one. I had about 150 lbs of music gear in Pearl's cargo area for a ...
LinkBack (1) Thread Tools
Old 09-22-2009, 08:49 PM   1 links from elsewhere to this Post. Click to view. #1
RadioMan
Mod Maniac
RadioMan's Avatar
My Car: 2010 Prius On Order
Model: II
Default Another Bizzare Gen 3 Anomoly
in Pearl's cargo area for a day. When I took out the gear,
the car was no longer parallel to the ground. Yup. It was lop-sided, closer to the ground on the driver's side by 1.75 inches. It stayed that way until I drove it a good while. I measured it from the rear body to the ground and the wheel-well to the tire. I couldn't bounce it back by hand. I stopped by the dealer and they checked it...all OK of course. I'll bet that there is something in the suspension that causes this to happen. I'm sure we will see this popping up on other Gen 3's.
Bob - Hot Springs
www.greenpowervideos.com
RadioMan is offline
The Following User Says Thank You to RadioMan For This Useful Post:
LaMesaGuy (09-24-2009)
Old 09-22-2009, 08:58 PM   #2
spiderman
Prius I am
spiderman's Avatar
Model: II
Default Re: Another Bizzare Gen 3 Anomoly
Very odd. Was it cold out during that time? Are you CO?
spiderman is offline
Old 09-22-2009, 09:59 PM   #3
TonyPSchaefer
Your Friendly Moderator
TonyPSchaefer's Avatar
Friends: 23
I think you'll find these threads interesting. Both talking about the same phenomenon.
Prius leans left
Prius Leans
TonyPSchaefer is offline
Old 09-23-2009, 11:20 AM   #4
garygid
Package: Navigation
Wow, 1.75 inch lean is a LOT of lean. It does not sound proper to me.
These other forums talk about alignment (the second link) and a small left lean (1/4 to 3/8 inch) in the Gen II vehicles.
I believe that this large amount of lean (1.75 inch) is unique, and the first reported in the Gen III (2010) Prius. As a "Large GenIII Lean", it is proper to gather more Gen III information here.
I will measure mine when I get a chance. I put 260 pounds of driver in the car. I have also had 240 on the passenger side along with 120 or so in the back passenger side.
garygid is offline
Old 09-23-2009, 05:54 PM   #5
kfalandays
shoot, I get lopsided for a few hours if I just sit the wrong way!
kfalandays is offline
Old 09-24-2009, 04:16 PM   #6
esoniat
Model: II
Maybe it is a retro thing. FJ40's and FJ60 did this. Mine leaned for over a decade before I put new springs under it.
Maybe I'll put a new suspension on my Prius when it is 20 year old too.
esoniat is offline
Old 09-24-2009, 04:27 PM   #7
cpatch
cpatch's Avatar
Package: Navigation
So it was leaning to the left? Perhaps it was making a political statement.
cpatch is offline
Old 09-24-2009, 04:42 PM   #8
jburns
Senior Senior Member
Bob - Hot Springs
This has reminded me of smething I saw several years ago. I was sitting in the supermarket parking lot waiting for my wife to finish her grocery shopping. She has banned me from going in with her. Funny thing is my mother did the same thing 50 years ago.
Anyway, while sitting there I noticed an old Olds 98 sitting in the parking lot with the drivers side almost down to the ground. I've never seen a car lean like that and figured both springs were broken. About that time out of the supermarket came a man that had to weigh at least 400 lbs. He got into the Olds and I swear you could hear the car go UGGHHH. So maybe it isn't the music gear at all.
jburns is offline
Old 10-14-2009, 07:46 PM   #9
RadioMan
Mod Maniac
RadioMan's Avatar
Model: II
Default Suspension problem /defect - Anyone Else?
OK, It has happened several times now. Whenever I put over about 50 lbs of gear in the trunk for a few hours, when I get the gear out, the car remains lop-sided. Yes, it is between 3/4ths and 1.5 inches lower to the ground on the drivers side- measured at the rear of the car. The wheel-well to top-of-tire and the car frame to ground are identical. You can't bounce the Prius like a normal car.
Only after driving it without luggage for a while does it equalize again. As little as a half-inch is visible to the eye. 1 inch looks really bad. Has anyone looked to see if this is happening to them? Help!
Bob in Hot Springs
RadioMan is offline
Old 10-14-2009, 07:53 PM   #10
Tickwood
Package: Navigation
Default Re: Suspension problem /defect - Anyone Else?
Bob in Hot Springs
I think there are a number of posts on this. It is not a bug, it is a feature.
Tickwood is offline
problems, suspension, uneven suspension
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/69364-another-bizzare-gen-3-anomoly.html
Gen III 2010 Prius Main Forum - PriusChat Forums This thread Refback 09-23-2009 03:18 PM
Bizzare aerodynamic whistling noise ystasino Gen II Prius Main Forum 2 01-10-2008 11:03 AM
Bizzare bluetooth experience naterprius Gen II Prius Audio and Electronics 3 01-17-2006 05:21 PM
