This is a discussion on I think I found a rattler finally. within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; On the passenger seat on the bottom side by the door there is a plastic panel with one screw towards ...
Old 09-30-2009, 04:20 PM   #1
Mitchellsprius
My Car: 2010 Prius On Order
Default I think I found a rattler finally.
On the passenger seat on the bottom side by the door there is a plastic panel with one screw towards the back and a inside clip towards the front. I found the clip unattached. I was able to re-clip it and hopefully I got the rattle. I try putting some felt there to deaden the sound and it work. But all that should be needed is for it to be clipped. My matrix had the same problems with clips that would come apart. The drivers seat is firmly attached.
Mitchellsprius is online now
Old 09-30-2009, 07:13 PM   #2
Frankblack0503
Frankblack0503's Avatar
Model: V
Package: Premium (Europe)
Default Re: I think I found a rattler finally.
Can you put that on picture 2 show it exactly...have also rattle over there somewhere...would be helpfull 2 see it where it's located... thx
Frankblack0503 is offline
Old 09-30-2009, 09:54 PM   #3
Mitchellsprius
Im not great with transfer of pictures. I will try to desbribe it better tell me if it works. Open up passenger door look at the side of the seat that faces door there is a plastic piece approx. 18' long and 4" wide move it or pull it to see if it seperates. The drivers seat is firmly attached. If you pull it out a little you can see a clip underneath that has to be snapped in place.
Old 10-01-2009, 03:06 AM   #4
Frankblack0503
Model: V
have looked but don't see what you mean.... :-/
Old 10-01-2009, 08:51 AM   #5
Mitchellsprius
Did you put your hand on that plastic piece and does it move. Compare both seats. I will try tonight to take a picture if not.
Old 10-01-2009, 11:02 PM   #6
Mitchellsprius
It is on the same plastic piece that you adjust the seat back and forth.
finally, found, rattler
I've finally found the secret to increase mpg wintechsw Gen II Prius Fuel Economy 12 09-25-2009 12:26 AM
Finally Found Something I Don't Like About My Prius Big-w Gen III 2010 Prius Main Forum 9 09-08-2009 12:51 PM
found a used prius to buy (FINALLY!) pvsteph7 Newbie Forum 8 02-08-2008 01:36 PM
Forget the 350Z Nissan I finally found a Prius lordmakemeworthy Gen II Prius Main Forum 8 01-31-2006 07:37 PM
*Finally* found my place in line... Wynder Gen II Prius Main Forum 8 11-29-2005 03:41 PM
