| This is a discussion on drive through car wash within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; I have a question,if car is put into neutral,traction battery is not charged. When I went through car wash with ... |
| Junior Member Join Date: Sep 2009 Location: Carmichael,ca
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 0
Friends: 0 | I have a question,if car is put into neutral,traction battery is not charged. When I went through car wash with me in it,you were supposed to put car in neutral. After I got through it traction battery only showed one digit. I understand from owners manual that if traction battery goes dead,you will not go anywhere,Is this right or is there another proceure for going though this type of car wash. |
| A Fairly Senior Member Join Date: Jun 2006 Location: Rockville, MD
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 201
Friends: 2 | Quote:
So, the moral of the story is to make sure you have several bars available before you go through the drive-thru, and to turn off your A/C. I'd been through the carwash a number of times in my Gen II Prius and never had this happen.
__________________ 2010 Prius IV with solar package Winter Grey with Misty Grey interior and dark grey floormats Took Delivery 7/31/2009 Previous car: 2006 Prius Package III, Classic Silver Metallic | |
| Dr Curious Join Date: Aug 2009 Location: Louisiana
My Car: 2010 Prius Model: II Package: No Package Thanks: 134
Friends: 0 | If you just leave it in N, and the last battery blip goes out, wouldn't the ICE just kick on and everything would be ok? |
| | #4 | ||
My Car: 2007 Prius Model: Package: #6 Thanks: 282
Friends: 11 | Quote:
I had to leave my car in N while they did a wheel alignment, and it ran the HV battery down to the purple bars after about 1 hour on the alignment rack. I left the heater blower fan on, so if I had turned it off completely, it wouldn't have discharged the HV battery as much while in N. The HV battery discharges because it supplies power to the DC to DC converter to supply the 12v power buss and recharge the 12v battery. | ||
| The Following User Says Thank You to dogfriend For This Useful Post: | radioprius1 (10-02-2009) |
Friends: 0 | Yikes! So what happens if the HV battery completely drains? |
Friends: 33 | I'm not sure how these drive through car washes work as I have never used on however the way to put the Prius into neutral and not run the battery flat is to switch off the car then with foot off the brake press power twice, this pits the car in accessory mode. Now select neutral. For maximum battery duration keep the AC off, radio off and lights off. You can leave the radio on really. When you get to the end put your foot on the brake, select park and press the power button once, then select drive and drive off. |
| The Following User Says Thank You to patsparks For This Useful Post: | eglmainz (10-02-2009) |
The type of car wash they are using has a conveyor system built into the floor that pushes the car through the wash by bumping up against the tires. The attendant parks the car just at the front so that the conveyor will bump the front tires and leaves the car in N so it will roll freely through the wash. My GF uses one of these with her Avalon, but I make it a point not to let others drive my Prius as much as possible. I avoid valet parking also. Trust No One. ![]() I concur with your description above, but pushing the Power button twice w/ foot off brake actually puts you in IG-On mode, not Acc Mode. You can't shift to N while in Acc mode, it will stay in P. | |
Friends: 11 | You have to go to the dealer and use their special battery charger. There are only a few in the entire US, so you might have to wait awhile until they can get it. That is why the car beeps at you and displays a message when you try to leave it in N. And there are numerous warnings in the owners manual. |
Friends: 33 | Quote:
The important thing is you press twice from off with foot off the brakes. | |
Friends: 2 | Quote:
Also, I had brought up the problem of N not charging the battery in the following thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/68185-dont-do-in-carwash.html | |
| car, drive, wash |
| Video: Prius Drive Thru Day 4 - Madison Green Drive Expo | Danny | Prius and Hybrid News | 0 | 07-23-2009 12:29 PM |
| If the drive batteries fail can you still drive the car gas engine only? | plumabob | Gen II Prius Main Forum | 6 | 06-26-2009 08:32 AM |
| Wash My New Prius Myself Or Go To A Car Wash?! | Grocked | Gen II Prius Main Forum | 52 | 06-10-2008 05:24 PM |
| Car wash or hand wash. Which is better for the environment? | SSimon | Environmental Discussion | 9 | 10-12-2007 11:27 AM |
| Car Wash | Mt View | Gen II Prius Main Forum | 13 | 11-09-2005 11:50 PM |
