| This is a discussion on 2010 Lower gas mileage after oil change within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Be cautious. Dealers may also put in 5 full quarts instead of the recommended amount which is 4.4 quarts (US),with ... |
| | #11 |
| Senior Member Join Date: May 2009 Location: seaside, oregon
My Car: 2010 Prius Model: III Package: Navigation Thanks: 0
Friends: 0 | Be cautious. Dealers may also put in 5 full quarts instead of the recommended amount which is 4.4 quarts (US),with filter change. When I changed my oil I used only 4 quarts and that was over 7,000 miles ago and the oil level is still in between the marks, about half way. Last fill up was 57.49 MPG, calculated. Oil, 0X20 Moibl 1 synthetic. alfon |
| | #12 |
| Junior Member Join Date: Sep 2009 Location: Arkansas
My Car: 2010 Prius Model: II Package: N/A Thanks: 0
Friends: 0 | I just called my dealer's service department and asked about the oil they use in a new 2010 Prius and was told it was 0W-20 synthetic oil. |
| | #13 |
Friends: 10 | Red... considering your location AND the time of year, part of your reduced mileage is caused by the switchover to winter formula gas. it will lower your mileage simply because it has less energy per volume. iow, your "gallon" of gas does not have a full gallon in it. additives were added to lower the freezing point of gas to keep it from freezing in the lines. the additives do burn, but do not provide as much energy. you will lose 2-4 mpg if nothing else changes. now, i know what your weather has been like the past week or so. so the rest of your decrease in caused most likely by the weather getting colder, especially in the morning. now how much will the weather change affect you?? that depends. the longer the commute, the less the effect. **edit** overfilling was an issue previously as it was not well known how much the mileage could be affected. considering the amount of "airplay" the overfilling issue has received here at PC, i doubt that is your issue. Toyota does monitor this website extensively and major concerns expressed by us are most definitely passed on to the dealers. my dealer takes it upon themselves to monitor this website as well.
__________________ My Blue 2010 : Last tank 541.9 @ 49.48 pump (56.7 MFD) 5.54 CPM, 21 MPH, Lifetime:5442.2 miles 56.5 MPG pump. (62.22 MFD) 4.72 CPM. Summer MPG 57.4 Winter: 49.5 My 2006 SPM: Last tank 376.6 miles @38.21 pump (40.8 MFD) 7.17 cpm winter mpg 49.64 summer mpg 53.41 lifetime: 42,563.5 miles 51.5 mpg pump (52.7 mpg MFD) 5.51 cpm My 2007 Zenn total "fuel cost" $166.58 on "about" 9599.7 miles. 1.74 cents per mile (granted i plug in for free at work!!) My Plate: DUALPWR (Dual Power) Last edited by DaveinOlyWA; 10-10-2009 at 12:29 PM. |
| The Following User Says Thank You to DaveinOlyWA For This Useful Post: | viprius (10-17-2009) |
| 2010, change, gas, lower, mileage, oil |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/70174-2010-lower-gas-mileage-after-oil-change.html | ||||
| Gen III 2010 Prius Main Forum - PriusChat Forums | This thread | Refback | 10-08-2009 06:44 PM | |
| New tires - Do Primera's lower gas mileage | mikenancy1 | Gen II Prius Main Forum | 1 | 10-19-2007 08:50 PM |
| Calculated mileage WAY lower than MFD per tank value. | butchbs1985 | Gen II Prius Fuel Economy | 10 | 03-30-2007 01:00 PM |
| EPA shows new lower mileage ratings | jkash | Prius and Hybrid News | 1 | 02-23-2007 11:45 AM |
| Higher speed equals lower mileage? Not always... | glenhead | Other Cars | 12 | 07-12-2006 05:14 PM |
| Hybrid buyers choosing Prius, Civic over lower-mileage models | Areometer | Prius and Hybrid News | 2 | 04-19-2006 12:38 PM |
