This is a discussion on POLL: What mode do you drive in and why what percentages? within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; I have found that in ECO mode, when needing more power, I just press the pedal harder and I get ...
View Poll Results: What mode and why with a guess of percentages of each mode
Just "Eco" mode almost exclusively 99+ % of the time 40 37.04%
Just "Normal" mode almost exclusively 99+ % of the time 19 17.59%
Just "Power" mode almost exclusively 99+ % of the time 2 1.85%
I drive "Eco" most and "Normal" occasionally 7 6.48%
I drive "Eco" most and "Power" occasionally 9 8.33%
I drive "Normal" most and "Eco" occasionally 9 8.33%
I drive "Normal" most and "Power" occasionally 14 12.96%
I drive "Power" most and "Eco" occasionally 2 1.85%
I drive "Power" most and "Normal" occasionally 6 5.56%
Voters: 108. You may not vote on this poll
Old 10-09-2009, 12:19 PM   #31
route246
Default Re: POLL: What mode do you drive in and why what percentages?
I have found that in ECO mode, when needing more power, I just press the pedal harder and I get all the power I need to enter a highway or go up a steep hill. I know it induces a "heavy pedal" feel, but it makes hypermiling easier.
route246 is offline
Old 10-09-2009, 12:40 PM   #32
sstoian
Model: II
In Power mode, I noticed the car responds quickly to any small pedal depressure. I tried yesterday to drive in Power mode on the freeway, but found driving in this mode
a bit annoying for driving at constant speed. After a few miles, I switched to Eco and the car was no longer "nervous".
sstoian is offline
Old 10-09-2009, 12:57 PM   #33
windstrings
Certified Prius Breeder
windstrings's Avatar
Good point... finding the magic zone is much easier in Eco mode.
Even in Normal mode, its easier than the GenII.
windstrings is offline
Old 10-09-2009, 02:23 PM   #34
Blind Guy
Model: V
Package: Adv. Technology
I have seen it mentioed in these posts that the ECO mode modifies A/C performance, this is NON-Scientific, but I noticed the other day playing with the modes and the A/C, that when the A/C was ON, and the mode placed in ECO, the Fan Speed was reduced from its normal speed in other modes, however, the air temperature seemed to remain constant. I had previously noticed that when operating in ECO mode the temperature didn't appear to change, I had thought the A/C temperature would probably need to be increased because of the ECO mode toning in down, and by raising the temperature in ECO, your defeating the purpose of the ECO A/C modification. ALL I noticed was a reduction in Fan Speed!
Just to double check this, I turned the A/C OFF, set the temperature and Fan Speed manually, and then, after running initially in Normal mode, it was placed in ECO, again, the Fan Speed was LOWERED! Leading me to believe maybe this is all the ECO mode actually does.
Let me know what you think.
David (aka Blind Guy)
Blind Guy is offline
Old 10-09-2009, 02:44 PM   #35
windstrings
I may be wrong, but lowering fan speed also lowers the cooling needed for the compressor and so less energy. To keep air at a certain temp, is easier if its moving slower because there is less cubic feet of air to deal with per second or minute.
I agree the fan alone is nil.
I also think it doesn't necessarily turn the fan or A/C down globally when going to Eco, but only when it deems its not advantageous to run at high. Then when the ICE is going to run anyway no matter what, it takes advantage of that window and runs the air extra hard to make up for lost time in an effort get the air temp modified to where you set it.
You may be doing your test at times when the ICE is not fully engaged and so the car thinks its a good time to save energy rather than use it on cooling.
I've been running before and all of a sudden the air kicks on like crazy when I didn't do anything, I"m assuming that's whats going on.
Again, I have not studied this but just going by memory of what I"ve heard in other posts..
If there is anyone who has actually done their homework, maybe they will chime in.
Alan
________________________
2010 Blue Ribbon Metallic IV with Bisque leather...."My Blue Baby"
And my "other" cars......
2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale"
2006 Silver Pine Mica Pkg#8 with Bisque leather.... "The Mint Julip"
2006 Mods so far:
1. Coastal EV switch 2. BT stiffening Plate 3.Zaino "the works" 4. Heat Shield "from Canvas Works" 5. Magnetic Oil plugs - Yes they work and you want them! 6. Speed sensor now switched!
Old 10-10-2009, 01:40 PM   #36
Blind Guy
Model: V
EXCELLENT points Alan, it's guys like you who keep us Newbees from getting a big head and imagining we know more than we really do!
Old 10-10-2009, 02:15 PM   #37
jarle
jarle's Avatar
Package: Executive
Originally Posted by Jasonsprite View Post
after playing with ECO and NORMAL i found that NORMAL gave the best mpg. i would use ECO if im stuck in traffic(stop and go).POWER when you need it. The EV mode's just a joke.
I also drive like this,as you say ev is no use the car autom goes to ev when it finds it useful
jarle is offline
Old 10-10-2009, 06:16 PM   #38
windstrings
No worries David... no matter how much you read and learn out here there is just too much to keep up with and you will always learn more.
There some really smart cookies out here that specialize in parts and pieces of the prius.
I'm just a guy who tries to glean enough myself to understand the big picture, but by no means knows much about anything.
Some of these guys are so far over my head I can't even read their threads and make any sense.
But when you get bored John has one of the coolest compilations of facts and information to study and make your head explode. It will give you a good foundation and understanding to go off of so some of the more advanced stuff starts to click.
It is very easy to get tunnel vision when we learn in a few areas but don't see the big picture.
The Following User Says Thank You to windstrings For This Useful Post:
Blind Guy (10-10-2009)
Old 10-10-2009, 06:38 PM   #39
windstrings
Until we go plugin with a vastly bigger battery, EV is of little use, but its not of "no" use.
I use it mostly when I first turn the car on and the prius insignia fires up... if you hit it at that moment, it will lock on and the ICE won't engage unless you breach one of the parameters that forces the ICE to come on.
Its useful if you want to move your car a few feet to wash it, or move it out of the way... or go a very short distance from point A to B "like around the block".. but speed is very limited. "10mph when the ICE is cold"
Its a nice novelty and sometimes actually is a nice tool.. but in large is of no real benefit. But you have to admit, its "cool" to have it and show off when you want to be sure the ICE doesn't come on!
The EV that really puts money back on your pocket is the one that is automatically done by the computer when coasting, braking, stopped at a light etc. And those times are usually not true EV, but the ICE is silently revolving with no spark or gas awaiting its next order to engage.
This allows undetectable seamless injection of power from the ICE when needed.
Every time we coast because traffic is in front of us, but then see it start moving before we get there, and we gently apply the gas again for power and the ICE engages without us ever knowing the difference.
If the battery is charged and we drive on a relatively flat surface 40 - 60'ish mph, it will look like we are in EV mode because we will see 70 - 100mpg on the gauge when in reality the ICE is freespinning or only partially utilizing its power and mostly utilizing energy from the battery.
The Prius is amazing in how it does what it does.
Reading some of the PDF's on Johns page helps to start to understand the complexity and marvels of the prius.
There are competitor hybrids out there that do well for what they are, but do it in a very clunky segmented "non seamless" way thats annoying and by no means leaves you with the feeling of driving a high end luxury car thats built to perfection.
It kinda makes me mad.. because I feel there "must" be a higher profit margin between the customer and the manufacturer to be able to sell so close to what a prius sells for with such clunky simple technology.
Fortunately for them, the public rarely appreciates the complexities of the prius.... they put the icing on the cake that makes it worthy of the party!
Some of those other cars feel more like a science project instead!
drive, mode, percentages, poll
Poll: How many miles do you drive per year? Momentum Gen II Prius Main Forum 53 10-13-2009 06:35 PM
Video: EV Drive Mode Demonstration Tideland Prius Gen III 2010 Prius Main Forum 0 03-26-2009 08:51 PM
Poll: How many miles do you drive your Prius nerfer Gen II Prius Main Forum 70 04-20-2008 12:39 PM
no EV mode during test drive bredekamp Gen II Prius Main Forum 17 07-23-2007 06:49 PM
Window tinting percentages...What is best? santoro1 Gen II Prius Main Forum 39 06-14-2007 01:39 AM
