| This is a discussion on B or Jake brake Question within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by richard schumacher Picky, picky... Pat means that the mechanical components are always engaged with each other, but ... |
| | #21 | |
| Senior Member Join Date: Apr 2009 Location: North Andover, MA
My Car: 2009 Prius Model: N/A Package: No Package Thanks: 3
Friends: 9 | Quote:
Back to the subject of the thread, B Braking is most useful in only heavy downhill situations which gets back to my original point in the first few comments on this thread. I said for MA drivers of which the OP and I are (except for the very few if any MA Prius drivers that happen upon the extreme north west part of the state over the highest point in the Berkshires at a less than impressive 3500 feet) B Brake is a useless feature. Except for that very small portion of the state, you will not find any heavy descents in MA that remotely require the use of B Brake.
__________________ ![]() ![]() *76.0 mpg 2nd place Hybrid/Diesel Division at 2009 AMEC Economy Competition in Fonda, NY (104 mile run on 8/23/09) * Best Tank (400+ miles): 66.0 mpg over 402.6 miles from 8/10-21/2009 My Facebook: http://www.facebook.com/photo.php?pi...?id=1268001941 My Twitter: http://twitter.com/bone1124 www.ecomodder.com Last edited by Matt Herring; 10-09-2009 at 11:47 AM. | |
| The Following User Says Thank You to Matt Herring For This Useful Post: | dave77 (10-10-2009) |
| | #22 |
Friends: 0 | "B" increases regeneration, which is inherently less efficient than gliding or coasting using light brake regeneration, and it will use some amount of engine braking, meaning that energy will be lost entirely. "B" really should only be used as an alternative to riding the brake on long steep downgrades. There's no benefit in it otherwise. Last edited by richard schumacher; 10-09-2009 at 12:03 PM. |
| The Following User Says Thank You to richard schumacher For This Useful Post: | dave77 (10-10-2009) |
| | #23 | |
| Member Join Date: Sep 2009 Location: Chicago, Il
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 0
By the way, your statement regarding "energy will be lost instead of recovered and stored in the battery for re-use" is misleading...ie, energy will be recovered and stored in the battery, if the battery is not fully charged. But as long as the battery is not fully charged, some re-charging of the battery does occur. I've seen it on my car. I've read it. So it does happen. Last edited by codybigdog123; 10-09-2009 at 12:14 PM. | |
| The Following User Says Thank You to codybigdog123 For This Useful Post: | dave77 (10-10-2009) |
| | #24 | |
My Car: 2006 Prius Model: Package: #7 Thanks: 94
Friends: 10 | Quote:
Tom | |
| The Following User Says Thank You to qbee42 For This Useful Post: | dave77 (10-10-2009) |
| | #25 | |
Tom, Thanks. I got all that, and yes, I understand that some regenerative energy is wasted in B. However, my point is still valid - when your foot is taken off the gas pedal, you do NOT consume fuel in the B mode, and unless the battery is at capacity, some of the regenerative energy goes back to the battery. Prior posts gave the impression that while in B, fuel is consumed, and no charging of the battery takes place.. That is wrong. I am not debating which method is superior. For some, with steep declines, the B mode is best. Under other circumstances, it isn't. That was my only point. Last edited by codybigdog123; 10-09-2009 at 01:41 PM. | |
| | #26 | |
| Senior Member Join Date: Feb 2009 Location: Western Washington
My Car: 2010 Prius Model: II Package: No Package Thanks: 22
Friends: 0 | Quote: On steep hills, regeneration fills the traction battery after just a few hundred vertical feet. Beyond that, the gravitational energy must be burned off somehow. | |
| The Following User Says Thank You to fuzzy1 For This Useful Post: | dave77 (10-10-2009) |
| | #27 | |
Tom | |
| | #28 |
Friends: 0 | Folks, please keep in mind that in the absence of other drag factors and starting from a "virtual dead empty" of 40% SOC, regen is only good for a MAXIMUM of 600 vertical feet. Then you're all-green and done. Same with the 2010, as it's got the same battery capacity and roughly the same weight. At that point you'd better be B-ing or burning. . _H* |
| The Following User Says Thank You to hobbit For This Useful Post: | dave77 (10-10-2009) |
| | #29 |
Friends: 33 | I have found that in B mode, a full green battery, descending a hill and my foot lightly on the brake the engine revs exceed 4000 RPM! That is some serious energy dumping. |
| | #30 | |
Tom | |
| brake, jake, question |
| Screeching P-Brake and another question | ystasino | Gen II Prius Main Forum | 2 | 10-30-2008 03:22 PM |
| Question about Gas and Brake. | pghavant | Gen II Prius Technical Discussion | 10 | 04-17-2008 01:55 PM |
| Question About Brake Warning Light on 2002 | Linda L | Gen II Prius Care, Maintenance and Troubleshooting | 0 | 03-23-2008 07:28 PM |
| Silly question... brake lights | Blegate | Gen II Prius Technical Discussion | 3 | 05-18-2007 06:43 PM |
| Brake replacement question | kkister1492 | Gen II Prius Care, Maintenance and Troubleshooting | 19 | 03-20-2005 05:03 PM |
