This is a discussion on Someone do a poll, noises and where built? within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Here's the link: http://www.toyota.com/help/contactus.html...
LinkBack (1) Thread Tools
Old 11-12-2009, 03:53 PM   #41
schoolchef
Model: II
Default Re: Someone do a poll, noises and where built?
Here's the link:
schoolchef is offline
Old 11-12-2009, 10:12 PM   #42
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
Originally Posted by schoolchef View Post
I'd be curious to know how many folks who hear rattling also ride solo in the vehicle.
Good point, I almost always drive alone and hadn't even thought of that. Next time someone is in the car with me I'll find a rough patch of road and check it out.
I just posted some information on a "Front Seat Squeak Noise" TSB in the other rattle thread in case anyone is interested, post #68.
Do you hear rattling noises?
tumbleweed is offline
Old 11-12-2009, 11:19 PM   #43
Bobsprius
BobPrius
Model: V
Everyone may want to check the heater covering under the Glovebox area. Mine was as loose as a goose! I was shocked but an easy fix!
Bobsprius is offline
Old 11-13-2009, 11:47 AM   #44
JeffA
"The Batmobile"
JeffA's Avatar
Package: Navigation
I have a "0" with minor rattles. They mosty eminate from the glove box doors and the center console as many have reported. I have found that both the upper and lower glove box doors are loose and when I apply pressure the noises go away. As for the center console, there is a thin line that runs the length of the console where the two pieces are joined. I've found that if I apply pressure directly to the joint that the noise subsides. I think felt might be the answer to most of the problems, I just need to do some disassembly. In addition, and I haven't read where anyone else has had this issue, but with the JBL sound system at higher volumes, I get both a intermittent pop from the front drivers side dash speaker, and the bass rattles everything else in the car...I guess I must have to minimize bumpin' my tunes at excessive levels.
You can have your iPhone 3G!
I have a Prius 3G!!!
JeffA is offline
Old 11-13-2009, 01:41 PM   #45
mwetter
Originally Posted by sshaw10 View Post
Don't know how to setup a poll but I wonder if someone could post one where owners could answer yes or no if they have squeaks and rattles and where their car was built. I wonder if there's a correlation to a particular plant(s). One post mentioned better quality from plant 0 versus plant 5.
I didn't think much of early reports of squeaks and noises but they seem to keep increasing.
I have a 0 bot the end of June. There are a few rattles, but nothing as annoying as there seems to be with some.
mwetter is offline
Old 11-13-2009, 05:10 PM   #46
gil
Model: V
Ours is a "0" purchased at the end of July, and so far so good. Only heard a squeak once, but will wait till it gets really cold to see what happens. Our 05 Prius had squeaks to entire time we owned it, but they were worse when cold. Most of them were around the small fillers between the forward side windows and the dash. I haven't heard this on the new one as these fillers appear to be coated with a felt material.
gil is offline
built, noises, poll
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/70941-someone-do-poll-noises-where-built.html
Gen III 2010 Prius Main Forum - PriusChat Forums This thread Refback 10-22-2009 06:41 PM
Squeaks and Noises yunebug Gen II Prius Care, Maintenance and Troubleshooting 1 06-30-2009 08:25 PM
question about noises MariaEvri Gen II Prius Technical Discussion 6 04-01-2009 06:41 AM
What do you think about starting this ancillary poll to the extended warranty poll ? sas0611 Gen II Prius Main Forum 2 07-25-2008 10:21 PM
wierd noises jazba Gen II Prius Care, Maintenance and Troubleshooting 8 05-14-2008 12:01 PM
Squeaks & noises jsorger Gen II Prius Care, Maintenance and Troubleshooting 4 04-24-2004 02:05 AM
