| This is a discussion on The big red E-stop button. within the Gen III 2010 Prius Main Forum forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by garygid If the car is runaway due to a simple throttle stuck under something heavy (mat, foot, ... |
| | #21 | |
| 2010PriusWannabe-Now an owner! Join Date: Apr 2009 Location: Leesburg Florida USA
My Car: 2010 Prius Model: V Package: No Package Thanks: 195
Friends: 4 | Quote:
I would hope THIS is a joke. The '10 Prius has "sudden unintended acceleration" in reverse? And "others have noticed this bug"? What the??? If not a joke - what's the story? Imagine backing out of a parking space, this occurs and you suddenly back into a stroller or such before able to brake harder to compensate. Can someone substantiate this supposed software bug --- or debunk??? | |
| | #22 |
| Prius I am Join Date: Jul 2009 Location: Alaska
My Car: 2010 Prius Model: II Package: Base Thanks: 121
Friends: 2 | |
| | #23 | |
| Senior Member Join Date: Jul 2009 Location: Adams, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 87
Friends: 4 | Quote:
| | #24 | |
| Senior Senior Member Join Date: Oct 2005 Location: Archdale, NC
My Car: 2010 Prius Model: III Package: No Package Thanks: 13
| | #25 |
My Car: 2008 Prius Model: Package: #2 Thanks: 116
Friends: 0 | |
| | #26 |
| Senior Member Join Date: Apr 2008 Location: Pennsylvania
My Car: 2008 Prius Model: Package: #6 Thanks: 5
Friends: 1 | |
| | #27 |
Friends: 2 | Guess what? You can buy a red start/stop button for the Gen III right this very moment! ![]() $199 from Sigma Automotive, Toyota Prius 2010 ZVW30 Performance, Handling & Electronic Accessories :: Sigma Automotive Wonder if it is a retro-fit to the Gen II. Last edited by Rokeby; 11-05-2009 at 06:56 PM. |
| | #28 |
Friends: 0 | While it true that the brakes will indeed hold the car stationary, I'm not so sure they could stop a car from high speed as well as the engine being at full power. Remember brakes work by converting kinetic energy into heat, they may not be able to handle that much heat if you were going say 70 or 80 MPH and accelerated 10 MPH or so before you recognized the problem and applied corrective action. |
| | #29 | |
| Member Join Date: Sep 2005 Location: Plymouth, Wi
My Car: 2010 Prius Model: II Package: N/A Thanks: 2
The Prius is an automated machine. Runaway Mode is a failure mode, your car has one. Hopefully you never see it. I have been behind the wheel of a runaway car before. The gas pedal cable stuck. Lucky that I had time and my speed was lower when it happen. Shifted to neutral , stopped and then turned off the key to stop the engine. The gas pedal cable was frozen because of ice. Here are my reasons for wanting a switch. 2 sec to neutral at 60 mph = 176 feet 3 sec to push the power button at 60 mph = 264 feet 5 sec to try both neutral and the power button = 440 feet plus That's a long way before the car even starts to slow down. The idea of a switch (The big stop E-stop ha ha...) Is to be quick...not what should I do first, neutral or power button...by than you will have travel another 176 feet. In some peoples cases they just resign to the fact that they are gone to die and forget about neutral or the power button. I have worked with and have designed control systems using the Big red E-stops. They are a requried part of any automated machine. I can sleep at night, know that the equipment which I have designed will and can be shut down when thing go wrong. Sure an E-stop system can fail or may not be ideal, that just another fact about automated equipment. If I get a chance to upload the electrical schematics, hacking in a switch maybe a simple task. Just thought someone may have done this before... and I could just wire the switch. The safety red flip cover is a good idea. | |
| | #30 |
Friends: 10 | Push Park. That causes the Prius to instantly switch to Neutral. Tom |
| The Following User Says Thank You to qbee42 For This Useful Post: | rachaelseven (11-08-2009) |
| big, button, estop, red, stupid idea, troll |
| PWR button typical way to stop CD? | cycledrum | Gen II Prius Audio and Electronics | 4 | 09-24-2008 10:40 AM |
| The Start/Stop button | WWJD08 | Knowledge Base Articles Discussion | 6 | 09-07-2008 08:18 AM |
| Best way to accelerate from a stop? | dprice23 | Gen II Prius Fuel Economy | 4 | 06-09-2007 02:58 PM |
| The Perfect Stop? | Anonymous | Gen II Prius Main Forum | 9 | 04-26-2005 04:37 PM |
