| This is a discussion on VIP RS3200 Plus Security System within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Well, you can flatbed a Prius, AND you could purchase the module and change it, then reprogram the main computer ... |
| | #11 |
My Car: 2007 Prius Model: Package: B Thanks: 3
Friends: 0 | Well, you can flatbed a Prius, AND you could purchase the module and change it, then reprogram the main computer to recognize the new module, -THEN- you could drive your stolen Prius. But you'd need access to the parts and to the programmer. You can't "hotwire" a Prius. I'm sure there are lots of dealer employees who could be tempted. But for a Prius (a car worth $25,000 ish used) it wouldn't be worth it. Even the parts wouldn't be a big seller - yet. Now Lexus, Mercedes, and BMW, that's another matter. An alarm won't protect the car contents from being stolen. They are so common, and go off so often nobody even looks anymore. How about storing stuff under the rear cargo box with the spare tire? Most thieves are too stupid/lazy to look there.
| | #12 | |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 33
| | #13 |
| Senior Member Join Date: Jul 2009 Location: Adams, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 87
Friends: 4 | I tried a key in the middle of the window, like the book said. Thankfully it didn't seem to do any damage. But it also did not set off the alarm or even the pre-alarm 'back off' beep. So I tried the butt end of a heavy fork (smooth) and tapped as hard as I dared. Nothing. I really felt like I would break the glass if I tapped any harder - I don't think I was being a wimp about it. I confirmed that the alarm works by using the window open technique, so the dealer really did install the alarm... or at least programmed the computer. But I'm starting to wonder if they actually installed the glass sensor. The little light where the glass break microphone is located also doesn't blink - it just goes out 30 seconds or so after arming. So is something wrong? Did my dealer fail to complete the installation? Rip me off somehow? They gave me an owner's manual to an RS3200 and put on the decal, so they must have had one. Any thoughts? Anyone actually make the glass break sensor trip? Thanks! |
| | #14 | |
| Senior Member Join Date: May 2005 Location: Pine, CO
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 6
| The Following User Says Thank You to Mt View For This Useful Post: | rachaelseven (07-28-2009) |
| | #15 |
Friends: 4 | Any chance that sensitivity can be adjusted without the Toyota maintenance computer thingy that only dealers have? |
| | #16 |
Friends: 0 | I know I was able to do it myself on a 2005 but I don't remember how. Actually on the 2005 the process was 1) buy the "kit", cut a small wire under the dash, install and adjust the glass breakage sensor, go to Toyota and pay the dealer $50 to turn it on. Except for the glass breakage sensor the system was already in the car just need to be turned on by cutting a wire and the dealer programming it. |
| | #17 |
Friends: 4 | Thanks for that. Inspired by your post, I've been googling the adjustment; and from what I've read, the sensitivity is just a knob on the RS3200 (at least in other cars), so if I can find the darn thing, maybe I can adjust it up and try it again. |
| | #18 |
Friends: 0 | On the 2005 it was near the center of the car way up under the dash. If you paid for it the dealer should have given you all the documentation, including installation instructions that came with it. If I had a dealer install it I would get them to adjust it correctly. You don't want it too sensitive or thunder will set it off. |
| | #19 | |
Friends: 4 | Quote:
| | #20 | |
| Member Join Date: Jul 2009 Location: CA
My Car: 2010 Prius Model: II Package: No Package Thanks: 1
The control unit for the alarm has a dial on it to adjust the sensitivity. It's supposed to be in the lower panel with the mirror adjust and whatnot. I haven't opened it up myself, but I've seen diagrams. | |
| The Following User Says Thank You to sciguy125 For This Useful Post: | rachaelseven (07-30-2009) |
| rs3200, security, system, vip |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/64310-vip-rs3200-plus-security-system.html | ||||
| Vip Rs3200 Plus Security System Links | This thread | Refback | 08-18-2009 03:55 PM | |
| VIP RS3200 Plus Security System - PriusChat Forums | caralarmsystems.info | This thread | Refback | 07-31-2009 06:08 AM | |
| Anyone have the 'VIP RS3200 Plus security system' on the 2010 prius? impressions? alarm | sferris | Gen III 2010 Prius Main Forum | 9 | 09-12-2009 08:45 AM |
| Adding RS3200 Plus Security System to '10 Prius III? | dbacksfan | Gen III 2010 Prius Main Forum | 4 | 05-07-2009 10:26 PM |
| Anybody added the Alarm system, Prius RS3200 Plus 2005-2006 | auart | Gen II Prius Main Forum | 2 | 08-31-2006 08:46 PM |
| What does the security system actually do? | 1playwonder | Gen II Prius Main Forum | 4 | 01-19-2006 09:33 PM |
| Toyota's VIP-RS3200 Security System | randalla | Gen II Prius Main Forum | 1 | 04-08-2004 04:15 PM |
