Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010+ Prius Technical Discussion
HSI details
Old 10-15-2009, 11:45 AM   #41
2010 Prius owner
Package: Premium (Canada)
Default Re: HSI details
Originally Posted by hobbit View Post
I read my forums in Lynx for a whole slew of very good reasons.
_H*
Maybe this would help, I'll have to try it on OS X to see if it works:
lynx-2.8 has an options screen (key 'O') which permits to set the display character set. When running in an xterm or Linux console in UTF-8 mode, set this to "UNICODE UTF-8". Note that for this setting to take effect in the current browser session, you have to confirm on the "Accept Changes" field, and for this setting to take effect in future browser sessions, you have to enable the "Save options to disk" field and then confirm it on the "Accept Changes" field.
Philosophe is offline
Old 10-15-2009, 02:51 PM   #42
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 31
If EBCDIC was good enough for my grandfather, it should be good enough for ... Now where did I put that key 026 punch machine ... Oh yea, by the ASR-33.
bwilson4web is offline
Old 10-19-2009, 09:51 AM   #43
Model: II
Package: Base (Canada)
I thought I'd ascii a question to get us back on topic...Earlier in the thread it was mentioned that ECO mode changes the cruise control response? I use ECO most of the time and Cruise a lot...I had hoped that ECO would change the throttle response in cruise but I can't detect any difference in cruise no matter which mode it is in (ECO Normal or power)...I'd prefer a smoother slightly less agressive cruise mode to use.
peirhead is offline
Old 10-19-2009, 10:08 AM   #44
tumbleweed's Avatar
Model: V
Package: Adv. Technology
I agree the cruise control applies to much throttle to get back up to speed if you use the resume function (as most of them do) and the ECO driving mode makes no difference. I use the throttle to return to within 1 or 2 MPH of the set speed before I hit resume.
tumbleweed is offline
Old 10-19-2009, 11:57 AM   #45
2010 Prius owner
Agreed. I do the same. I would have liked it to maintain accelerations under the PWR zone, still allowing the driver to accelerate faster by pressing the gas pedal directly (for safety reasons in some situations).
I would also like the cruise control in ECO mode to avoid regenerative breaking to keep the speed down. I have to slightly depress the gas pedal to avoid it when going down slopes.
In fact, I would like to be able to turn off (dealer setting) the "automatic-transmission-like" feature that automatically brakes/accelerates the car when no pedal is pressed; giving us a real neutral instread of fiddling with the pedal to keep the HSI in neutral.
2010 Prius.
Lifetime average: 4.5L/100km displayed (4.9L/100km calculated)
Last tank average: 4.7L/100km (@ 3°C average temp)
Old 10-28-2009, 11:00 AM   #46
hobbit's Avatar
I have updated the HSI page, taking out the remaining "XXX"
unanswered-question sections since for the most part they've
been answered now. On a whim I called a local dealership and
arranged a test-drive to clear up some last little bits of info;
they are credited in the document and the astute will notice a
hint as to how to see more information about that day.
Don't let this stop anyone from confirming/denying anything
I've said in there, though -- I don't drive one of these every
day, it's you folks with the eyeballs and butt-dyno and MPG
figures and hopefully eventual real instrumentation that are
really going to come up with all the good subtleties.
_H*
hobbit is offline
Thanked by 3 Users:
jdcollins5 (12-05-2009), sdleo726 (12-05-2009), undrgnd (12-07-2009)
Old 12-05-2009, 08:41 AM   #47
sdleo726's Avatar
_H*
thanks hobbit et al. the Tao of HSI has been the most informative explanation of how to drive the Gen3 Prius and achieve optimal performance.
sdleo726 is offline
Old 12-18-2009, 03:25 PM   #48
Model: II
Excellent doc, Hobbit. I read it last night.
A minor points, for us newbies:
Following your advice to try to stay in the "upper half" (efficient engine zone) of the eco-zone on the highway today, I noticed that when using the "resume" function on cruise control (upward tap on lever), the engine generally went into the red PWR zone on HSI. So you might want to suggest that folks resume speed "manually" ("pedally"???) staying in the efficient engine zone, and reset the cruise control when you get to the right speed.
Is this correct? Or am I missing something?
May have some more questions later.
kgall is offline
details, hsi
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/66411-hsi-details.html
Diário de Bordo 2G - Alexandre Moleiro - Prius-PT This thread Refback 09-09-2011 04:41 AM
Diário de Bordo 2G - Alexandre Moleiro - Prius-PT This thread Refback 08-29-2011 04:05 PM
Mi Toyota Prius - Indicador del sistema híbrido (HIS) - FAQ Prius 3G This thread Refback 12-29-2010 10:59 AM
How to drive your third-gen - CleanMPG Forums This thread Refback 11-26-2010 10:33 PM
Mi Toyota Prius - Indicador del sistema híbrido (HIS) - FAQ Prius 3G This thread Refback 07-27-2010 10:46 AM
How to drive your third-gen - CleanMPG Forums This thread Refback 05-10-2010 05:26 PM
Mi Toyota Prius - Indicador del sistema híbrido (HIS) - FAQ Prius 3G This thread Refback 05-10-2010 05:03 PM
EV Kit Details tmanson Gen II Prius Modifications 8 05-19-2008 03:37 PM
Car Talk: Details, Details zenMachine Gen II Prius Care, Maintenance and Troubleshooting 0 10-02-2007 02:40 PM
2008 Model Details? AVOID92X Gen II Prius Main Forum 7 06-14-2007 09:51 AM
CAN-view details on SOC charge mparrish Gen II Prius Fuel Economy 1 05-18-2007 01:23 AM
06 Tax CREDIT details gqscientist Gen II Prius Main Forum 3 12-13-2005 01:12 AM
