This is a discussion on Confirm Light Sensor in IV or below? within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by jayvee Tried this last night. There is a signal there, but not what it is supposed to ...
Old 08-22-2009, 12:22 AM   #21
lecounte
lecounte's Avatar
My Car: 2010 Prius On Order
Default Re: Confirm Light Sensor in IV or below?
Originally Posted by jayvee View Post
Tried this last night. There is a signal there, but not what it is supposed to look like, and when grounded, has no apparent effect on the headlights.
I also found out the that the Canada ECU (with true auto on/off headlights) is indeed a different part number, so probably is programmed differently too. If I had gotten this to work, I was intending to replace my headlight stalk with a Canada stalk, which has the "Auto" position. Unfortunately, I also discovered that the Canadian headlight stalk is on the RIGHT! (never knew that - I wonder why?)
So it's back to the drawing board......
On the RIGHT??? is that right? In the manual it shows on the left. I thought the manual was for US and Canada like the warning lights. Can someone in Canada tell us for sure?
lecounte is offline
Old 08-24-2009, 02:24 PM   #22
jayvee
Package: Navigation
I agree that TIS and the manual shows only one.
The dealer showed me the diagram when he pulled up the part number, and it was on the right. However, he was moving pretty fast on the parts screens, and it would be good for someone else to confirm. He showed two different part numbers for US and Canada, Canada on the right, US on the left. Maybe he pulled up the wrong diagram.....Time for a quick thread to confirm?
UPDATE: A Canadian owner confirmed that the headlight stalk is in fact on the LEFT, as in the US. My parts tech was apparently showing me another country's diagram....
jayvee is offline
confirm, light, sensor
Sensor Light jb72 Gen III 2010 Prius Main Forum 4 06-19-2009 01:27 AM
Want to purchase DRL Light Sensor California Mike Canadian International Prius Club 0 07-06-2008 03:58 PM
How much too low is the air in the tires when the sensor light is triggered?? priusmaybe Gen II Prius Care, Maintenance and Troubleshooting 1 11-10-2007 11:38 PM
Light Sensor on Windsheild Marvinh Gen II Prius Main Forum 4 08-06-2007 04:06 PM
Oxygen sensor and check engine light walkinghat Gen II Prius Care, Maintenance and Troubleshooting 1 03-30-2007 01:56 PM
