| This is a discussion on Air Con not working in Accessory Mode? within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by LRKingII Foot off brake and 2 pushes on power button when parked. 1 push. 2 pushes gets ... |
| | #11 | |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 370
Friends: 26 | 1 push. 2 pushes gets you to IG-ON (or ON in other cars). 1 push gets you to ACC or accessory. Quote:
| | #12 |
| jay_man_also Join Date: Jun 2009 Location: Manassas, VA
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 58
Friends: 3 | When you hit the power button once without a foot on the brake the radio comes on. Hit it again and the fan starts blowing and the rest of the dash lights up. All I know is every time I've done it I get cold air from the vents, but that may just be the fan pushing already cold air around. |
| | #13 | |
My Car: 2008 Prius Model: Package: #2 Thanks: 165
The little 12V battery won't run the AC compressor. It could probably run the blower (don't know if it does or not as I haven't tried.) Conventional cars can't run the actual AC compressor with the engine off since it is belt driven off the engine. The Prius can use power for the traction battery to run it when in ignition on mode. | |
| accessory, air, con, mode, working |
| Dash 12v Accessory Receptacle Not Working | grathke | Gen II Prius Audio and Electronics | 5 | 05-03-2009 01:41 PM |
| Day Mode option not working - 2008 | MattFL | Gen II Prius Main Forum | 5 | 12-09-2007 10:07 AM |
| Accessory mode question | eej5 | Gen II Prius Main Forum | 7 | 02-28-2007 07:10 PM |
| electric only mode accessory | jbond31560 | Gen II Prius Audio and Electronics | 9 | 04-15-2006 11:19 PM |
| Can't turn off the Prius in Accessory mode | bcool | Gen II Prius Main Forum | 5 | 03-25-2005 08:54 AM |
