| This is a discussion on Tire Pressure Sensor in Spare? within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by Boo That would be ideal. Which car has that now? Porsche does, and I suspect some/all of ... |
| | #21 |
| Senior Member Join Date: May 2008 Location: SF Bay Area
My Car: 2010 Prius Model: V Package: Navigation Thanks: 58
Friends: 2 | |
| | #22 | |
| Relevance is irrelevant Join Date: Aug 2008 Location: St. Louis, MO
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 21
Friends: 13 | Quote:
| | #23 | |
| jay_man_also Join Date: Jun 2009 Location: Manassas, VA
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 58
Friends: 3 | Quote:
| | #24 |
| Senior Member Join Date: May 2009 Location: Boston
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 6
Friends: 0 | My wife's Caddy also displays psi for each tire, and it seems pretty accurate. I assume the Prius sensors are not very accurate, so that even if all tires were at the same pressure, each sensor would report slightly different numbers. If those readings were displayed, it would drive us nuts and we would complain. It seems that for a few bucks (okay a few hundred bucks) the sensors could be more useful. What does Lexus do? |
| | #25 | |
My Car: 2007 Prius Model: Package: #2 Thanks: 167
Friends: 22 | Quote:
So if the TPMS is set for 40 psi, then if any of the 4 tires drops to 30 psi, then the TPMS warning light icon should go on. | |
| | #26 |
| Senior Member Join Date: Jul 2009 Location: Adams, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 87
Friends: 4 | The Prius system does record the pressure for each tire and set an individual threshold for each one. You can see each pressure listed separately and each associated threshold when you look at the Techstream device. The car doesn't display all 4, which could be annoying or helpful, depending on your point of view; but it does process each one individually and set separate threshold values for each one. From what I can see, the threshold is less than 20% - my 48.2psi fronts have thresholds of 40.6psi and my 46.0psi rears have thresholds of 38.4psi... looks more like an 8psi spread to me. The system also seems to track internally down to the tenth of a psi, as you can see from the readings above. And interestingly, it also tracks temperature as well as pressure, down to the nearest degree F. |
| | #27 | |
Friends: 2 | Quote:
| | #28 |
Friends: 4 | |
| | #29 | |
If the past is any indication, Toyota doesn't seem to favor mid-generational changes. E.g., it took Toyota a whole generation to move the driver seat's furthest rearward travel point back 2.5 inches. IMO, they could have made this change in 2005 and it would have cost no more than a few pennies or dollars per car. | |
| | #30 | |
| Senior Member Join Date: Jul 2009 Location: Memphis
My Car: 2010 Prius Model: III Package: Navigation Thanks: 23
This brings up my new definition of an optimist. It's the guy or gal who wrote the Prius manual and said: "Make sure to check the inflation pressure as part of your daily vehicle checks (p439)" Anybody out there checking their tire pressure daily? Weekly? Be honest
__________________ my Prius ! | |
| sensor, spare tire, tire pressure, tpms |
| tire shop broke a TPMS tire pressure monitor sensor during tire change | theorist | Gen II Prius Care, Maintenance and Troubleshooting | 32 | 04-08-2009 11:57 PM |
| Tire Pressure Sensor Question | peach | Gen II Prius Main Forum | 7 | 07-26-2007 12:39 PM |
| Turning Off Tire Pressure Sensor | vinnysca | Gen II Prius Main Forum | 0 | 09-05-2006 10:31 PM |
| Tire pressure sensor | mssmith95 | Gen II Prius Main Forum | 2 | 06-04-2006 02:09 PM |
| Tire Pressure Monitor, where is the sensor? | DocVijay | Gen II Prius Main Forum | 28 | 12-19-2005 06:08 PM |
my Prius !
