| This is a discussion on Car Wash Caused Hybrid System Warning within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by maledyris I've been trying to figure this out too. I don't think it will work. The problem ... |
| | #21 | |
| Senior Member Join Date: Jul 2009 Location: Adams, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 87
Friends: 4 | Quote:
| | #22 | |
| Senior Member Join Date: Aug 2009 Location: WA
My Car: 2010 Prius Model: IV Package: Navigation Thanks: 43
All good theories...but just like how many licks it takes to get to the center of a Tootsie Pop, "the world may never know"........ | |
| | #23 |
| Senior Member Join Date: Jun 2009 Location: Washington DC
My Car: 2010 Prius Model: III Package: No Package Thanks: 9
Friends: 0 | I routinely use a touchless wash and have had only one problem: the last time the outdoor temperature sensor got stuck at 68 degrees (water temperature?) and didn't start rising back to actual ambient temperature until about 15 minutes later (including about 10 minutes at interstate speeds). After I got home (about 20 minutes), it had finally risen to approximately the proper temperature, and it was seemingly back to normal after that. |
| | #24 | |
| Member Join Date: Jul 2009 Location: CA
My Car: 2010 Prius Model: II Package: No Package Thanks: 1
One of the nastiest specs in there is that the electronics are supposed to tolerate a train of 2ms -100V spikes (yes negative with two zeros). Not that I recommend shorting the traction battery to the 12V system. | |
| | #25 |
| Senior Member Join Date: Jul 2009 Location: Worthington, Ohio
My Car: 2010 Prius Model: III Package: Navigation Thanks: 7
Friends: 0 | I hand washed my 2010 Prius yesterday, and several times the car would beep whenever I ran my wet sponge over the driver side door knob. No harm done though, and everything was normal after I finished washing it. |
| | #26 |
| BobPrius Join Date: Jul 2009 Location: Buffalo
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 9
Friends: 1 | Jim, Same thing happened to me when washing mine. I didn't have the FOB in my pocket but close enough to the car to note it's proximity. Once I placed it farther away, no more beeping or locking or unlocking happened. A learning curve. Thanks for your post as well... |
| | #27 | |
My Car: 2008 Prius Model: Package: T3 Thanks: 7
The high-voltage battery's positive and negative terminals are completely disconnected from the rest of the car, the return path being a second conductor. The negative point therefore could give any reading at all compared to the chassis if you read it with a voltmeter. 'Ground' is really a term from transmission-line systems such as power distribution, where the Earth itself (i.e. the planet) is used as the return path. Poor connections to 'ground' on one sensor, compared to the ECU that measures the value, can cause sensor values to be wildly out of range, because the two ground points have a potential difference between them (connecting a meter across the two points would show some voltage difference). Some of the car's sensors (e.g. coolant temperature sensor) are connected at two points, to provide a good reference ground, rather than being connected to the chassis. Some ECUs have multiple ground points and therefore can even show incorrect voltages within the ECU itself. An ECU fault should be diagnosed first by checking all relevant ground points, in my view. So, if there was a short between the battery positive terminal and the chassis, the ECUs would see that as a reduced voltage on the power connections - likely they'd momentarily switch off. | |
| | #28 |
| Junior Member Join Date: Sep 2008 Location: Michigan
My Car: 2009 Prius Model: Package: #6 Thanks: 0
Friends: 0 | Went through an auto carwash today after filling the tank but forgot to replace the gas tank cap. This is a high pressure water jet wtih no brush type of car wash. I wonder how bad it affected the car. I have the gen III prius. Appreciate any feedback. |
| | #29 | |
Friends: 33 | Quote:
Would be best to have the tank drained and then refill. I wouldn't drive the car until the water was removed. That's my opinion. | |
| | #30 |
Friends: 0 | Thanks, I will do that first thing Monday. I should be able to drive for few miles to the dealership since it's got full tank right now. |
| car, caused, hybrid, system, warning, wash |
| Master Warning Light/Hybrid System Warning | panache | Generation 1 Prius Discussion | 6 | 07-20-2009 10:06 PM |
| Hybrid System Warning Light On - Car won't go | larkydoo | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 02-14-2008 09:18 AM |
| Hybrid System Warning Light (!) on | Screaming Red | Gen II Prius Technical Discussion | 0 | 09-20-2007 11:22 AM |
| Hybrid System Warning Light!!!! Help!!!! | ReallyFrustrated | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 05-17-2005 02:40 AM |
| WARNING!! Isopropyl Alcohol caused dash discoloration | hybrid4earth | Gen II Prius Care, Maintenance and Troubleshooting | 6 | 03-17-2005 12:45 PM |
