This is a discussion on Car Wash Caused Hybrid System Warning within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Except the water might get into the fuel system. You can't remove the filter in the prius, it's all integrated ...
Old 11-08-2009, 08:56 AM   #31
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
Default Re: Car Wash Caused Hybrid System Warning
Except the water might get into the fuel system. You can't remove the filter in the prius, it's all integrated inside the fuel tank, pump and all. I hope very little has gone into the tank.
patsparks is offline
Old 11-09-2009, 06:06 PM   #32
aapoppa
formerly known as "Popoff"
aapoppa's Avatar
Model: V
Package: Navigation
Originally Posted by patanci View Post
Thanks, I will do that first thing Monday. I should be able to drive for few miles to the dealership since it's got full tank right now.
Not a good idea. Water will pool in the bottom of the tank, no matter how full it is, and possibly slosh into the fuel inlet line. Fuel injection systems do not like water.
Best call your dealer and ask them what to do. If it were mine, I would not drive it without a mechanic's approval.
aapoppa is offline
car, caused, hybrid, system, warning, wash
Master Warning Light/Hybrid System Warning panache Generation 1 Prius Discussion 6 07-20-2009 10:06 PM
Hybrid System Warning Light On - Car won't go larkydoo Gen II Prius Care, Maintenance and Troubleshooting 4 02-14-2008 09:18 AM
Hybrid System Warning Light (!) on Screaming Red Gen II Prius Technical Discussion 0 09-20-2007 11:22 AM
Hybrid System Warning Light!!!! Help!!!! ReallyFrustrated Gen II Prius Care, Maintenance and Troubleshooting 3 05-17-2005 02:40 AM
WARNING!! Isopropyl Alcohol caused dash discoloration hybrid4earth Gen II Prius Care, Maintenance and Troubleshooting 6 03-17-2005 12:45 PM
