| This is a discussion on Lock 2010 Prius using key fob with air-conditioner running within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; I need to lock my 2010 Prius with the air conditioner running when I leave the car. I am travelling ... |
#1 |
| Junior Member Join Date: Aug 2009 Location: Melbourne, Fl
My Car: 2010 Prius Model: IV Package: No Package Thanks: 1
Friends: 0 | I need to lock my 2010 Prius with the air conditioner running when I leave the car. I am travelling with dogs in the car and must make short (5 minute) rest stops in high heat. With other cars I lock the car and left the motor and air-conditioner running. The key FOB has outsmarted me. Any ideas? Thanks. |
| Member Join Date: Jul 2009 Location: Rockville MD
My Car: 2010 Prius Model: IV Package: No Package Thanks: 2
Friends: 0 | It's not nearly as convenient as using the fob, but you could lock all doors using the automatic locks BEFORE you open the driver's door. Then open the driver's door, close it, and use the mechanical key to lock the driver's door. The car will be locked and running until you come back where you'll have to again use the mechanical key to unlock the door. |
| The Following User Says Thank You to JasonPro For This Useful Post: | mmaggio (09-22-2009) |
Friends: 10 | Use the mechanical key. As a side note, since the Prius engine will be off much of the time, you may want to leave a sign in the window saying that the dogs are okay and air conditioning is running. Otherwise some well intentioned person is going to break your glass to rescue the dogs, or otherwise make a scene. Tom |
| Member Join Date: Aug 2009 Location: Australia
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 2
| Senior Member Join Date: Jul 2009 Location: Adams, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 87
Friends: 4 | I was thinking of a thermometer on a suction cup on the inside of the window, right next to the note. I'm worried you're right though, that someone would not get the point and try to 'save' my dog just the same. But I figure the thermometer might give me better odds and I'm still going to have to give it a try eventually. |
| Senior Member Join Date: Jun 2009 Location: Orlando
My Car: 2010 Prius Model: III Package: Solar Roof Thanks: 12
Friends: 0 | just used this feature yesterday while traveling with our dog. left the remote in the car and used the metal key to lock the doors. worked great. as a side note, if you use the metal key. when unlocking the door, turn key once for drivers side, turn twice to unlock all doors. also, remember to use the emergency brake just in case the dog figures out how to put the car in gear. ;-) Last edited by RadioZero; 09-11-2009 at 08:47 AM. |
| | #7 | |||
| Canonus Curiosus Join Date: Aug 2007 Location: Chicagoland (West)
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 150
Friends: 18 | Quote:
What you did was to leave the car running AND give a thief the opportunity of a lifetime: A Prius already running WITH the key fob available! Perhaps not everyone knows the Prius quirks as well as some of us Prius nuts, but it is possible (and maybe not that difficult) to get into your car in that situation. Because the key fob is nearby (even though it is inside the car and not outside), the antenna could be ready to send/receive info. Because the system is already ON, it may be more susceptible to this scenario. Pouring a decent amount of water over the sensor on the door handle is likely going to be enough to unlock the door(s). For those of you who've washed your cars with a key fob in your pocket, you'll know that this happens. You'll hear the car beep to signal it is unlocked (just as when you place your hand on the door handle). Once this happens, the doors may be opened for 60 seconds. Someone who knows what he is doing will simply open a water bottle and pour it over the door handle sensor until the car beeps and the doors are unlocked. I believe the antenna system is only supposed to lock or unlock if the key fob is outside the car, but I haven't read that in the Owner's Manual, nor have I tested it out. Perhaps someone can confirm. In any event, this is much too risky a scenario. Please ALWAYS keep the electronic key (key fob) in your possession. If nothing else, it is the best place to store the mechanical key! Quote:
I do recall reading about someone whose dog was able to shift the car into neutral. This is particularly easy on the Gen3, because the shifter is on the console, and you only need to hold it for a second or two on "N" in order to shift the car to neutral. Use of the parking brake prevents the car from just rolling away.
__________________ Previous Prius: 2007 Silver Pine Mica Pkg #6. 29,492 miles. Lifetime: 52.2 MPG; Last Rolling 12 Months: 53.4 MPG Current Car: 2010 Blue Ribbon Metallic Prius V w/ AT Pkg. (from 5/25/09) Lifetime City Mileage: . . . . . . . 57.7 MPG Lifetime Highway Mileage: . . .56.8 MPG Lifetime Combined Mileage:. .57.1 MPG @ 8,242 miles Best Trip Odo: (778.7 mi at 20 mph): 60.6 MPG & (390.0mi at 47 mph): 64.5 MPG | |||
| Senior Member Join Date: Jun 2009 Location: Cleveland, OH
My Car: 2010 Prius Model: IV Package: N/A Thanks: 0
Friends: 1 | You can not shift into any positions with out your foot on the break |
| 2010 Prius owner Join Date: Jun 2009 Location: Montréal, Québec (Canada)
My Car: 2010 Prius Model: N/A Package: Premium (Canada) Thanks: 19
Friends: 0 | Another trick to avoid leaving a FOB inside: While in the car, running, lower the driver's window, open the door and get out, leaving the FOB on the seat. With your arm through the driver window, lock all doors, get the FOB and then pull the automatic window-up button. Voilà. The car is running, all doors locked and it thinks the FOB is still inside (you cannot exit the car with all doors locked so the FOB MUST still be inside!). Use the mechanical key to unlock the door when you need to (neither the SmartLock of the FOB button will work as the car thinks the FOB is inside the car).
__________________ 2010 Prius. Lifetime average: (yet to be calculated) Current tank average: 4.7L/100km |
| | #10 | ||||
| Senior Member Join Date: Jul 2009 Location: Carlsbad, CA
My Car: 2010 Prius Model: III Package: Navigation Thanks: 10
Friends: 2 | Quote:
| 2010, airconditioner, fob, key, lock, prius, running |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/68682-lock-2010-prius-using-key-fob-air-conditioner-running.html | ||||
| Lock 2010 Prius using key fob with air-conditioner running - PriusChat Forums | This thread | Refback | 09-25-2009 06:51 PM | |
| Can't lock 2008 Prius - it beeps continuously but door won't lock. | sesimon | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 09-25-2009 08:31 AM |
| 07 Prius Air Conditioner Randomly Quits. | treyi | Gen II Prius Care, Maintenance and Troubleshooting | 14 | 04-16-2009 01:50 PM |
| Strange sound when running air conditioner | wacko999 | Gen II Prius Main Forum | 1 | 10-02-2004 08:40 PM |
| Air conditioner always on? | trapperjohn | Gen II Prius Main Forum | 17 | 08-21-2004 02:51 PM |
| Air Conditioner | jkash | Gen II Prius Main Forum | 1 | 03-07-2004 10:21 PM |
