This is a discussion on Surprised no 12v power outlet in the back within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; I can't believe the Gen 3 doesn't have a 12v power outlet in the back...I see there is an option ...
Old 09-25-2009, 09:45 PM   #1
peirhead
Model: II
Package: Base (Canada)
Default Surprised no 12v power outlet in the back
I can't believe the Gen 3 doesn't have a 12v power outlet in the back...I see there is an option for one if you get the rear centre armrest, but otherwise!!!! I think it is obvious to have one back there and was very surprised to find none when I went to plug in my koolatron fridge!! Anyone put one in back there themselves??
peirhead is offline
Old 09-26-2009, 03:03 AM   #2
jayvee
Package: Navigation
Default Re: Surprised no 12v power outlet in the back
I've been thinking of adding this at the rear of the front console, using the same parts as the outlet inside the console (with spring-loaded cover plate) - assuming there is room in the open space under the console. It would be about $40 in OEM parts.
jayvee is offline
Old 09-26-2009, 07:28 AM   #3
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
I put one in the back of my Gen II, it was very easy too. Sorry I know nothing about the console of a G III.
patsparks is offline
12v, back, outlet, power, surprised
Center Console Power Outlet and Front (Cigarette outlet) How to mod Always hot?? Prius07Pkg4 Gen II Prius Audio and Electronics 15 01-18-2009 11:37 AM
12v Power outlet Pat Down Under Gen II Prius Modifications 7 04-08-2007 09:04 AM
07 Prius Power Outlet mod??? ruggb Gen II Prius Modifications 2 01-04-2007 06:42 PM
Adding a 12v power outlet in the back dmacmitchell Gen II Prius Audio and Electronics 4 07-13-2006 12:08 AM
power outlet mod ernda Gen II Prius Audio and Electronics 4 02-26-2006 08:25 PM
