| This is a discussion on Minimum/Maximum tire pressure on 17' wheels within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by a priori All three OEM tire choices for the 17" wheels on US Prius models (2010, that ... |
| | #11 | |
| Member Join Date: Aug 2009 Location: SF Bay Area, CA
My Car: 2010 Prius Model: V Package: N/A Thanks: 1
I checked the sidewall rating on my 17" Michellin OEM tires and it states a max of 44 PSI. But, when I checked the specs online it states 51 PSI. Do you why there is a difference? Thanks. | |
| | #12 |
| Senior Member Join Date: Apr 2009 Location: Pacific Northwest
My Car: 2010 Prius Model: III Package: Navigation Thanks: 110
Friends: 0 | |
| | #13 | |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 33
I just checked the TireRack.com site for OEM Michelins for the Prius V and they show this tire which is 44psi: Tire Specs for Michelin Pilot HX MXM4 If these are the tires you have I would say the 44 is correct. BTW they are on sale for $113 ea, a real bargain if someone needed tires. | |
| | #14 |
My Car: 2007 Prius Model: Package: B Thanks: 3
Friends: 0 | I -still- want to see a picture of those 17 foot wheels! (we've seen this typo before). |
| | #15 |
| Gas miser Join Date: Jun 2006 Location: NH
My Car: 2006 Prius Model: N/A Package: #9 Thanks: 3
Friends: 0 | |
| | #16 |
Friends: 35 | I run my Kumho Ecxsta ASX's at 51psi (sidewall max). I tried runnin 58/56 but I couldn't tell if MPG got any better so I dropped the pressure for a bit more ride comfort. I tend to hit corners pretty hot so I like having well inflated tires. |
| | #17 |
| Junior Member Join Date: Oct 2009 Location: Monterey
My Car: 2007 Prius Model: N/A Package: S Touring Thanks: 0
Friends: 0 | The maximum pressure shown on the side of the tire is for safe operation of the tire which will be mounted on different cars with different gross vehicle specs. Toyota gives a recommended pressure for the stock tires on the Prius that is going to be safe for any tire you put on the car. As with the Bridgestone & Ford Explorer problems an under inflated tire is more dangerous and likely to experience a catastrophic failure so it is better to err on the side of too much air where the only downside is likely to be reduced tire life and increased slippage while cornering. Higher pressures will provide high mpg but that should not be your only concern. Having an accident due to increased breaking distance or control of the car is going to quickly eliminate any savings accrued from the higher gas mileage. If I get 10% better mileage with my Prius my fuel cost savings at 12,000 miles a year (even in California with the highest prices in the nation by far) would be $80 a year of about 22 cents a day - hardly worth shortening the tread life of the tires or chancing the safety of me and my passengers. With my trucks where 40K was normal and tires are quite expensive compared to most car tires it took a couple sets and experimentation to get the optimum tire and pressure to get the most miles per set of tires. I have gotten even wear at the Toyota's recommended tire pressures with the OEM tires so that will be the starting point for the replacement tires as well. If I lived in a cooler part of the country I could see increasing the pressure during the winter months. |
| | #18 | |
Friends: 35 | Quote:
Integritys with over 35k miles @ 50+psi (pics) 20k miles on Nokian i3 tires at 50+psi Now compare this to how many owners complain about how quickly their tires wore out while running the recommended tire pressure. It appears that the very narrow tires (modern tires) do not suffer the same problems we used to see with older designs on wider tires (275/45/17).
__________________ 2005 Prius - Upgrades: Kenwood eXcelon KDC-X993, Diamond Audio D9800.2 and D61500.1 (1900w RMS), Diamond Audio D971 7" component set, 2 Diamond Audio D910D4 10" subwoofers (600w/ea). ![]() California Rangeland ConservationCoalition Ranchers, Environmentalists, And Agencies Working Together For The Benefit Of All. | |
| minimum or maximum, pressure, tire, wheels |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/69677-minimum-maximum-tire-pressure-17-wheels.html | ||||
| correct tire pressure for 17 rims - Zuula Search | This thread | Refback | 10-29-2009 12:30 AM | |
| Tire Pressure Light On After New Tire Installation | JoelMarcey | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 07-18-2009 12:59 AM |
| tire shop broke a TPMS tire pressure monitor sensor during tire change | theorist | Gen II Prius Care, Maintenance and Troubleshooting | 32 | 04-08-2009 11:57 PM |
| Scion Wheels And Tire Pressure Sensors | max2prius | Gen II Prius Modifications | 5 | 12-06-2008 11:34 AM |
| forget the maximum, what's the minimum MPG? | busyrosy | Gen II Prius Main Forum | 60 | 11-13-2006 04:32 PM |
| Got a question about tire pressure on upgraded wheels... | vinnysca | Gen II Prius Main Forum | 1 | 09-21-2006 10:38 PM |
