This is a discussion on Buffeting turbulance inside the car. within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; I was on the freeway doing about 60mph and rolled my drivers window down all the way, and all I ...
Old 10-02-2009, 04:53 PM   #1
Anthony
Model: II
Default Buffeting turbulance inside the car.
I was on the freeway doing about 60mph and rolled my drivers window down all the way, and all I heard was WUB,WUB,WUB,WUB,WUB!!!!! Kinda similar to having the rear windows down in a car when the fronts are closed.
I have never had this happen to any car before. I just cracked open the passenger side and the nice was gone. I know it has to do with the shape and aerodynamics of the car, but you would think they would allow you to roll the drivers side window down without the noise and pressure in your ears.
Anthony is offline
Old 10-02-2009, 08:23 PM   #2
jayvee
Package: Navigation
Default Re: Buffeting turbulance inside the car.
This has happened on every car I have owned, to varying degrees, especially above 40 mph. It seems the more aerodynamic the car is, the worse the 'effect".
Wait, it may not have happened on my '67 Chrysler Newport... But I wouldn't exactly call that car aerodynamic....
jayvee is offline
Old 10-02-2009, 08:30 PM   #3
It happens with any of the newer cars with good aerodynamics. With older cars and trucks there is so much external turbulence that an open window doesn't make much difference. If you want to drive your Prius with an open driver window, experiment with also opening one or both rear windows a bit. You should be able to find a combination that will eliminate most of the buffet.
Old 10-02-2009, 09:31 PM   #4
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
I find having all the windows all the way up seems to eliminate this noise. I use the AC over 70km/h and weather permitting I have window down under 70km/h. Saves your ears.
My dad went deaf from driving on country roads with the window down. Dad was a truck driver and delivered newspapers by throwing them out the window into people's driveways along the highway.
patsparks is offline
Old 10-02-2009, 09:50 PM   #5
a64pilot
I think maybe those plastic covers for the edge of the windows may help with this, not sure because I have never had any
a64pilot is offline
Old 10-02-2009, 09:52 PM   #6
Rae Vynn
Tree-hugging Vegan Witch
Rae Vynn's Avatar
Friends: 66
We had the same thing with our 2007 Prius, so we installed the Window Deflectors, which helps. Doesn't eliminate, but it helps.
You get better MPG if you have the windows UP and the AC on over ~45 mph, anyway.
Rae Vynn is offline
The Following User Says Thank You to Rae Vynn For This Useful Post:
patsparks (10-03-2009)
Old 10-02-2009, 10:25 PM   #7
DaveinOlyWA
3rd Time was Solariffic!!
DaveinOlyWA's Avatar
ya i drive with the back windows down because that thumping sound make me fantasize that i got a 1500 watt sub woofer in the hatch
DaveinOlyWA is offline
Old 10-02-2009, 11:19 PM   #8
Anthony
Model: II
We have a 2008 Toyota Sienna, and I have a 2002 dodge ram, and never heard this before. Now if the kids open the rear windows on the van, man my ear drums pop out of my head.
Anthony is offline
Old 10-03-2009, 12:14 AM   #9
mgb4tim
Noob
mgb4tim's Avatar
Package: Navigation
happens to every sedan I've owned, open the window behind it a couple inches - benefit, you won't get a face full of wind, either
mgb4tim is offline
Old 10-03-2009, 01:55 AM   #10
spiderman
Prius I am
spiderman's Avatar
Model: II
We have a Kia sedona van and one time while driving on the highway the kids ran the rear window down and I literally could not hear them screaming... it was soooo loud.
I have not tried this in the Prius.
spiderman is offline
buffeting, car, inside, turbulance
What do you keep inside your prius? alasnik Gen II Prius Main Forum 55 08-13-2008 01:25 PM
LED inside light's Flying White Dutchman Gen II Prius Modifications 34 03-06-2008 03:22 PM
Stuck inside my car. perryma Gen II Prius Main Forum 4 02-09-2008 04:33 PM
Washing Inside and Outside Tlyke1983 Gen II Prius Care, Maintenance and Troubleshooting 5 08-16-2007 10:36 PM
Rain on inside? Renocat Gen II Prius Main Forum 3 09-14-2006 05:25 PM
