This is a discussion on Antenna schematics on the US 2010 within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Does anyone have access to the stock antenna (AM FM) schematics? We know the EU has an antenna amp. I ...
Old 10-02-2009, 11:39 PM   #1
rrolff
Prius Surgeon
rrolff's Avatar
Default Antenna schematics on the US 2010
We know the EU has an antenna amp. I looking to both locate that amp, find if it powered and how, and possibly swap it.... If you can help, many I think will appreciate it (of course me included ().
TIA!!!
Rolf
rrolff is offline
Old 10-03-2009, 01:14 AM   #2
jayvee
Package: Navigation
Default Re: Antenna schematics on the US 2010
Follow the beige antenna lead that plugs into the receiver assembly, back to a white connector, which is L36. This appears to be to the upper left, behind the radio assembly. That connector plugs into the antenna amplifier. There is no separate power lead on the schematic, so if it is powered, it is powered through the antenna lead itself (which is somewhat common for antenna amplifiers).
It appears in the schematic that the antenna is directly attached to the amplifier (no connector), so I'm not sure you'd be able to replace it.
jayvee is offline
Old 10-03-2009, 01:27 AM   #3
RodJo
RodJo's Avatar
Model: V
Package: Adv. Technology
TIA!!!
Rolf
Nothing on the TIS site?
Similarly, I was planning to explore (eventually) the cellular antenna connection used for Safety Connect to see if I can couple my cellphone to it for better reception. I assume it also goes through an amp, which may be the same box.
I guess you didn't see anything when you had your dash off? I assume you peeked around in the rear cargo area too. It shouldn't be that well hidden.... Or could it be?
RodJo is offline
Old 10-03-2009, 01:35 AM   #4
RodJo
RodJo's Avatar
Model: V
Are the Safety Connect connectors also shown on the schematic?
Thanks.
RodJo is offline
Old 10-03-2009, 02:41 AM   #5
jayvee
Package: Navigation
Thanks.
Yes, on a separate TIS schematic (EWD). If you're wondering about the cell phone and GPS antennae, they both show as going directly into L19, a white 38-pin connector, which plugs into the "Telematics Transceiver". Unfortunately, I haven't found exactly where this is, in any location diagrams. Sorry!
jayvee is offline
Old 10-03-2009, 10:41 AM   #6
RodJo
RodJo's Avatar
Model: V
Thanks for the help. Once I get my Prius I'll poke around and see if I can find it.
RodJo is offline
Old 10-03-2009, 03:56 PM   #7
rrolff
Prius Surgeon
rrolff's Avatar
Hrmm - I don't get it - an antenna amp should have some power - something somewhere? Or could this antenna just run straight back to the roof
I know I bought a DTV antenna for my car - it has an antenna, but also 12VDC power and ground...
rrolff is offline
Old 10-04-2009, 01:48 PM   #8
a64pilot
Power can be run in the same coax as the signal, think GPS antenna and you satellite TV LNA's for example.
a64pilot is offline
Old 10-04-2009, 05:17 PM   #9
jayvee
Package: Navigation
Exactly.
jayvee is offline
Old 10-05-2009, 02:31 PM   #10
rrolff
Prius Surgeon
rrolff's Avatar
Exactly.
So, the $10K question remains - how does the antenna get its power....
rrolff is offline
2010, antenna, schematics
xm antenna NORTHPORT Gen II Prius Audio and Electronics 2 12-18-2008 11:14 AM
Hi, I'm new...do YOU have an antenna? bayareapriusdriver Newbie Forum 13 05-18-2008 04:57 PM
Sirius antenna under shark fin antenna efusco Gen II Prius Audio and Electronics 13 04-14-2008 05:31 PM
XM antenna jmanning Gen II Prius Technical Discussion 8 03-13-2008 11:05 PM
Obtaining Toyota amplifier schematics Chucka Gen II Prius Audio and Electronics 7 04-12-2005 03:51 PM
