This is a discussion on plug in traction battery charger within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; I'm looking for information on just topping off the traction battery with a plug in charger. What effect would it ...
Old 10-11-2009, 09:42 AM   #1
esoniat
Model: II
Default plug in traction battery charger
I'm looking for information on just topping off the traction battery with a plug in charger. What effect would it have. It would seem like an inexpensive low impact add on.
I see this was asked before about 3 years ago but no recent activity. I can not find anything with Google.
Is there a fundamental problem with topping off the traction battery with a plug in charger or is the improve so absurdly marginal that nobody bothers with it. I would think that even if the later were the case somebody would sell one, I've seen no shortage of marginally ethical "green" vendors out there.
esoniat is offline
Old 10-11-2009, 10:00 AM   #2
hobbit
hobbit's Avatar
Default Re: plug in traction battery charger
"Absurdly marginal" is an eloquent way to put it, and quite
true as far as any real advantages.
_H*
hobbit is offline
Old 10-11-2009, 10:08 AM   #3
Flying White Dutchman
Friends: 9
there is a good reason wy 3 years ago this question is asked and now your asking it again....
its useless.
to small of a diferents
Old 10-11-2009, 10:51 AM   #4
Silent Propulsion
Silent Propulsion's Avatar
Model: II
I would love to have some sort of plug in charge for mine. My situation is this: I take kids to school (two in one direction and one the other), get home and park. I usually have 2-3 battery bars at this time. I sleep during school hours (about 6 hours, perfect time to get some battery bars back). I pick the kids up from school and still end up with about 2-3 battery bars when done. My drop off/pick up routes usually charge the traction battery a couple of times as the route consists of long uphill/downhill roads where I live. I am holding my breath for some sort of add-on feature to come along.
Silent Propulsion is offline
Old 10-11-2009, 10:53 AM   #5
Friends: 9
and what do you want to pay for a option or after market part like that?
Old 10-11-2009, 11:02 AM   #6
Silent Propulsion
Model: II
$19.97 at Walmart!, Just kidding. My guess would be a couple of hundred dollars or less. I'm not one to look at what investment costs set me back, I look at instant savings. In this case, My traction battery would be more charged from the start, obviously using the ICE less.
Old 10-11-2009, 11:34 AM   #7
Using the ICE less, for about one mile.
Old 10-11-2009, 11:56 AM   #8
David Beale
David Beale's Avatar
Keep in mind you would have to ensure the charger doesn't charge the battery more than the 80% Toyota wants. More would surly void your battery warranty and would probably shorten the battery life. Then there is the problem of convincing the HSD that the extra charge is actually -in- there. Good luck finding an inexpensive charger that can do that for a 200VDC battery. I could design one fairly easily that could reliably put the charge in, but that couldn't tell the system it's in there.
So assuming you -could- find one to do that, you would be adding about 20% charge -most- of the time (the Prius tries to keep the battery at about 60% charge).
Going from about 60% charge to about 40% charge (where the HSD drops you out of EV mode) will give you 1-1.5 mi. of travel. So about that for 20% charge. So you'd be adding 1-1.5 mi. of EV capability for a total of 2-3 mi.
There is hope for you, however. There are aftermarket EV systems you can add that will at least triple your EV range. They include chargers. Cost varies from about $5000 to about $12,000. They are discussed ad-infinitum on this forum. Search for EV conversions.
Edmonton Alberta
David Beale is offline
Old 10-11-2009, 07:17 PM   #9
Silent Propulsion
Model: II
Yeah, but that one mile would get me to a long downhill road, thus charging the traction battery. And yes, I do know that in this case, what goes down must go up, and going uphill I get 25 MPG and going downhill indicates 100 MPG so what's the average???
Old 10-11-2009, 09:47 PM   #10
ken1784
SuperMID designer
ken1784's Avatar
Package: G
Friends: 8
It is hard to find/design a proper charger to maintain the battery in good condition.
It is too risky to invest a charger for getting "absurdly marginal" gain.
Have you ever considered the warranty issue?
Ken@Japan
ken1784 is offline
The Following User Says Thank You to ken1784 For This Useful Post:
taxachusetts (10-13-2009)
charger, plug in, traction battery
Plug option with stock traction battery aeronaut Gen II Prius Modifications 4 02-23-2008 01:29 AM
Cell phone power charger STUCK in in-dash AC plug! scotteeboy Gen II Prius Main Forum 18 11-22-2007 12:58 PM
Traction battery charger? chogan Prius and Hybrid News 1 06-05-2007 07:15 PM
Where to plug cell phone charger? thejoker Gen II Prius Audio and Electronics 8 07-06-2006 05:35 PM
HV Battery Charger Dr.Jay Gen II Prius Main Forum 9 03-07-2005 10:44 PM
