This is a discussion on 2010 Prius>PCS Button>Gen III within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Hello! I can't locate the PCS button on the 2010 Gen-III Prius? Owners manual said its located on the bottom ...
Old 10-23-2009, 02:45 PM   #1
priusworld
Model: V
Package: Adv. Technology
Default 2010 Prius>PCS Button>Gen III
Hello! I can't locate the PCS button on the 2010 Gen-III Prius? Owners manual said its located on the bottom left hand side of dash-board. It isn't there? I bought this Gen-III with this new option. I just want to make sure this PCS is activated and not "OFF".
Any feed-backs on the "Trident" interior/exterior protection spray agent? Dealer claimed you'll never have to wax your car for 6-8 years.
Thanks,
Hybrid King
priusworld is offline
Old 10-23-2009, 03:19 PM   #2
ggood
ggood
ggood's Avatar
Model: V
Friends: 6
Default Re: 2010 Prius>PCS Button>Gen III
If it is off, "PCS" is displayed on the dash display.
The switch is down there just under the dash, more to the right than is shown in the manual (just to the right of the steering column, I think). It's 2 or 3 inches away from the TPMS switch, which it resembles. Both are kind of hard to find the first time without getting down underneath and peering up at it. After you know where they are, you eventually get to where you can find them by feel.
ggood is online now
The Following User Says Thank You to ggood For This Useful Post:
priusworld (10-30-2009)
Old 10-23-2009, 03:36 PM   #3
Blind Guy
Model: V
Thanks,
Hybrid King
* With your palm UP, run your hand in line with the steering column underneath the Dash, about 6"s or so and a little to the right, you'll feel 2 concave buttons side by side about 2-3"s apart, the one on the Left is the TPMS Initialization and the one on the Right is the PCS button.
And the 2nd poster is correct, if the PCS is OFF, PCS will be illuminated in the MID.
David (aka Blind Guy)
Blind Guy is offline
The Following User Says Thank You to Blind Guy For This Useful Post:
Old 10-23-2009, 04:12 PM   #4
mgb4tim
Noob
mgb4tim's Avatar
Package: Navigation
Pcs??
mgb4tim is offline
Old 10-23-2009, 05:22 PM   #5
ggood
ggood
ggood's Avatar
Model: V
Friends: 6
Originally Posted by mgb4tim View Post
Pcs??
Pre-Collision System. It's part of the AT (advanced technology) option package available on the V model. It cinches up the seatbelts and pre-conditions and/or hits the brakes if it senses an impending collision.
ggood is online now
Old 10-24-2009, 12:31 PM   #6
priusworld
Model: V
Pcs??
Pre-Collision System. It's part of the AT (advanced technology) option package available on the V model. It cinches up the seatbelts and pre-conditions and/or hits the brakes if it senses an impending collison. Thanks!
Old 10-24-2009, 12:36 PM   #7
priusworld
Model: V
Thanks David I'll check it out. The last time I looked all i could find was the parking assist buttons. Is it near those switches? Have you heard anything about a good extended warranty program for our Priuses?
Thanks again..
Marty
Old 10-24-2009, 01:04 PM   #8
Bobsprius
BobPrius
Model: V
Thanks again..
Marty
The button is actually located slightly beyond the steering column, UNDER the dash more, it is not front facing where the parking assist button are, but underneath the dash section. You have to sort of lay under the steering column the first time and look up to the underside to see the buttons. I used a 17 LED Flashlight and could see it well with that...Once you know the location you will always remember it going forward.
Bob
Bobsprius is offline
2010, button>gen, iii, prius>pcs
No button to disable Smart Key System on 2010? xray22 Gen III 2010 Prius Technical Discussion 9 10-19-2009 08:33 AM
EV prius button???!!! thecan Gen II Prius Main Forum 25 05-01-2006 12:39 PM
My New Prius, The EV Button, and the WAF DanCole42 Gen II Prius Main Forum 8 04-21-2005 10:33 AM
EV Button for Classic Prius? daniel Gen II Prius Modifications 2 09-16-2004 07:18 AM
Do Canadian Prius have the EV button? Kacey Green Gen II Prius Fuel Economy 2 09-01-2004 07:50 PM
