This is a discussion on grill blocking / aerodynamics within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by Philosophe I doubt that reducing the air flow through the engine compartment will reduce whole car drag, ...
Old 10-27-2009, 06:14 PM   #11
Fred_H
Misoversimplifier
Fred_H's Avatar
Package: #5 Touring
Default Re: grill blocking / aerodynamics
Originally Posted by Philosophe View Post
I doubt that reducing the air flow through the engine compartment will reduce whole car drag, and may in fact do the reverse…
Originally Posted by gazz View Post
This was the point of my post, could you be increasing drag by blocking the airflow at the grill.
The short answer is no.
The long answer is here.
Fred_H is offline
The Following User Says Thank You to Fred_H For This Useful Post:
Rokeby (11-03-2009)
aerodynamics, blocking, grill
Grill Blocking dapastaguy Gen II Prius Modifications 2 01-27-2009 09:25 AM
grill blocking donalmilligan089 Gen II Prius Modifications 12 11-05-2008 11:35 PM
Blocking and unblocking the grill? homerj742 Gen II Prius Fuel Economy 8 02-02-2008 06:41 PM
Grill blocking and warranty BoltonJoe Gen II Prius Main Forum 13 01-30-2008 10:33 AM
Blocking the grill New2Prius2008 Gen II Prius Main Forum 28 01-07-2008 07:24 AM
