| This is a discussion on grill blocking / aerodynamics within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; In the UK the weather is getting colder, on my Prius Gen II I blocked the grill. The thing is ... |
| Senior Member Join Date: Mar 2007 Location: Coventry, UK
My Car: 2010 Prius Model: N/A Package: T4 Thanks: 8
Friends: 0 | In the UK the weather is getting colder, on my Prius Gen II I blocked the grill. The thing is on the Gen III it does not look so right to do, the air looks as if it is funneled into the engine bay and the blocking will upset the aerodynamics. Any thoughts on the blocking the grill on a Gen III aerodynamic. Most of my driving is below 50mph. Gary |
| Prius I am Join Date: Jul 2009 Location: Alaska
My Car: 2010 Prius Model: II Package: Base Thanks: 119
Friends: 2 | Quote:
How cold is it where you are, the gen III in eco mode seems a lot better, does not loose as much heat. Will be interesting to see what it does in the depths of winter. Last edited by gazz; 10-26-2009 at 05:08 PM. | |
Friends: 2 | Quote:
I have noticed my Prius seems to retain heat well (at least better than my 97 Camry). | |
Friends: 2 | The Prius, like any car, is designed to operate from the Arctic Circle to the Equator. In very warm climes, you can't have too much ICE cooling air. Elsewhere, it is entirely possible to have too much. The problem is once air is in the engine bay, it has to get out. That usually means abruptly into the air stream under the car, or out through the front wheel wells -- there are some exceptions in full bodied race cars; louvered fender vents. The abruptness causes greater drag somewhere down stream. The aerodynamic MPG gain on grill blocks comes from having less air in the engine bay to get rid of. This is of course is in addition to helping keep additional heat in the engine bay for thermodynamic efficiencies. A word of caution. IIRC, the ICE runs most efficiently up around 180- 195 degF. With grill blocks in and air temps above 65 degF it is easy to exceed these temps. If you're going to do full upper and lower grill blocks, it is best to also have an ICE monitor, something like the ScanGauge does fine. The current info on the Gen III is the cooler for the inverter is high on the radiator so fully blocking the upper grill may not be a good idea. Fot the Gen II the cooler is low down on the radiator. Last edited by Rokeby; 10-26-2009 at 05:50 PM. |
| The Following User Says Thank You to Rokeby For This Useful Post: | gazz (10-26-2009) |
| Senior Member Join Date: May 2009 Location: Boston, MA
My Car: 2010 Prius Model: IV Package: Navigation Thanks: 23
Friends: 0 | Here's another thread about grill blocking the Gen III. It has some useful guidelines about how much to block for given temperature ranges. I don't think you're likely to need a full block given the temps in the UK. You're a wee bit milder than us in New England (and our friend in Alaska!) http://priuschat.com/forums/gen-iii-...-strategy.html |
| The Following User Says Thank You to Bica2go For This Useful Post: | gazz (10-26-2009) |
| Misoversimplifier Join Date: Apr 2007 Location: Germany
My Car: 2007 Prius Model: Package: #5 Touring Thanks: 10
Friends: 0 | Just a reminder: There are two different desired effects of grill blocking. 1. Increase combustion engine temperature 2. Decrease aerodynamic drag Which lead to two interconnected things that one should keep in mind when grill blocking: 1. Try to reduce airflow mainly to the combustion engine radiator and not so much the Inverter radiator. 2. Try to minimise the total amount of air that goes through the grill, as opposed to routing it around the radiator after it passes through the grill. Ideally, there would be three separate airtight plenums, one for each heat exchanger, each of which which would be separately regulated. Practically, a more cost effective method is to block the air right at the grill, except for an area directly in front of the inverter radiator.
__________________ The Stone Age did not end for lack of stone, and the Oil Age will not end for lack of oil. 2007 Toyota Prius sol, 4.7 l/100km (50 mpg) Previous car: 1998 Mitsubishi Carisma 1.8 GDI, 250,000 km, 5.5 l/100km (42 mpg) |
| 2010 Prius owner Join Date: Jun 2009 Location: Montréal, Québec (Canada)
My Car: 2010 Prius Model: N/A Package: Premium (Canada) Thanks: 19
With all the air tunnel time spent on the Prius, one could think that the air flow around the car was planned to efficiently blend in the air rushing out of the engine compartment. Hence, blocking the grille may disturbed that planned air flow and have a nagative impact, could it? Anyway, this negative impact would probably be a lot smaller than the positive impact of having the engine warm faster (and stay warm) in the cold season. Personally, I have fully blocked the lower grille and 50% (1 row only) of the upper grille. I want to keep some air flowing through the inverter radiator. Weather normals at this time of the year here are max 9°C and min 1°C.
__________________ 2010 Prius. Lifetime average: (yet to be calculated) Current tank average: 4.7L/100km | |
| aerodynamics, blocking, grill |
| Grill Blocking | dapastaguy | Gen II Prius Modifications | 2 | 01-27-2009 09:25 AM |
| grill blocking | donalmilligan089 | Gen II Prius Modifications | 12 | 11-05-2008 11:35 PM |
| Blocking and unblocking the grill? | homerj742 | Gen II Prius Fuel Economy | 8 | 02-02-2008 06:41 PM |
| Grill blocking and warranty | BoltonJoe | Gen II Prius Main Forum | 13 | 01-30-2008 10:33 AM |
| Blocking the grill | New2Prius2008 | Gen II Prius Main Forum | 28 | 01-07-2008 07:24 AM |
