| This is a discussion on Slashdot discussion of "sudden acceleration" within the Gen III 2010 Prius Technical Discussion forums, part of the Gen III (2010+) Toyota Prius Forums category; At the risk of being accused of , I would suggest that Toyota's "sudden acceleration problem" has a lot more ... |
| | #11 |
| Senior Member Join Date: Jul 2009 Location: Adams, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 87
Friends: 4 | At the risk of being accused of , I would suggest that Toyota's "sudden acceleration problem" has a lot more to do with GM's sales numbers than it does with Toyota's cars. |
| | #12 |
| Senior Member Join Date: Sep 2009 Location: Vernon Hills, IL
My Car: 2010 Prius Model: V Package: Navigation Thanks: 7
Friends: 2 | I can't remember in which magazine I read it years ago (Automobile or Car & Driver) where they put unsuspecting people in different cars (including a 5000 Avant) to get their impressions on subjective concerns. At random times, they could trigger a "blip" in the Audi's throttle to see what the driver would do. Typically this was done while the driver was performing an "agility and visibility" test by doing a reverse slalom through a set of cones. Unfailingly, the drivers would attest they had the brake pedal all the way to the floor and, unfailingly, photo evidence showed the brake lights were unequivocally off. Sure, there may have been ergonomic issues which predisposed the vehicle to pedal misapplication. However, at the end of the day, it was driver error at the root of the cause and not some demonic possession which caused the 5000 to rocket off into the pachysandra at breakneck speeds, mowing down small children on tricycles and the elderly crossing the street with their walkers in the process.
__________________ Chris -- 2010 Blizzard over Dark Grey V+Nav |
| | #13 |
| Junior Member Join Date: Jun 2009 Location: Washington DC
Friends: 0 | Not related to the floor mat thing, but I've noticed when the car is warming up that there is a slight surge acceleration at about 20mph. I have only noticed it twice and it's only slight, say 1mph, but disconcerting. |
| | #14 |
Friends: 12 | If there really is a problem with the Prius drive-by-wire throttle, we're in deep doo-doo. Almost every new vehicle on the road now, foreign and domestic, uses drive-by-wire throttle and CANBus. The newest cars use FlexRay, an evolution of CANBus I have no doubt that out of hundreds of thousands, or perhaps a million vehicles, a handful won't have some sort of glitch. Nobody can guarantee anything to be 100% In that context, until it happens to you, runaway cars are a statistical oddity. Thanks to the (lack of) driver training these days, nobody knows how to change a flat tire, operate a stick shift, properly park on a hill (Hint: wheels turned IN or OUT?), or shift a transmission into neutral I've had direct personal experience with a WOT runaway, but that was around 25 years ago. I helped a buddy rebuild a 350 V8 to put into a '69 Chevy C10 pickup, which had originally come with a 327 To save money, he reused a lot of parts, especially the carb return spring. Everything went together fine, fired right up, we then took it out on an isolated road to break it in He hit the pedal a little harder, and suddenly all four barrels were wide open. He shifted into N, killed the ignition (Flooded the engine too, as the carb was still wide open), and we coasted to a stop in the rich smell of gasoline The return spring had broken right by hook which goes onto the carb throttle lever. I held the carb wide open while he cranked it. When it finally fired, I snapped the throttle closed, then we turned around and slowly putted back to his place. Easy solution: new return spring The other experience wasn't as dramatic. The Ford work truck at my hobby farm uses a throttle cable. After +20 years, it became frayed and would sometimes stick at around 1/3 pedal. The solution was simple: a new throttle cable
__________________ 2007 Toyota FJ Cruiser 5AT "C", Sun Fusion |
| | #15 |
Friends: 4 | And if there isn't, which is much more likely give the fact that no such problem has EVER been demonstrated, this whole thing is just a few jammed floor mats, a few bad drivers, and a whole lot of media scaremongering to drum up ratings... result of which will be that Toyota will get an unearned bad rep, the resale value of our cars will be destroyed, future models will be crippled somehow, and a whole bunch of unscrupulous lawyers will get rich. |
| | #16 | |
Friends: 10 | Quote:
Tom | |
| | #17 |
Friends: 0 | |
| | #18 |
| Junior Member Join Date: Oct 2009 Location: Carlisle, PA
My Car: 2010 Prius On Order Model: III Package: N/A Thanks: 4
Friends: 0 | I had this happen to me the other day....it scared me a little. I was coming to a stop over some rippled pavement on a downward slope and I noticed the CHG section of the display bar was lighting up and then the car surged forward for just a second with very little break control. If there was someone in front of me it would have been a hit. Be very careful slowing down on rippled pavement! |
| | #19 | |
Tom | |
| | #20 | |
| Senior Senior Member Join Date: Oct 2005 Location: Archdale, NC
My Car: 2010 Prius Model: III Package: No Package Thanks: 13
| sudden acceleration, throttle by wire |
| Abnormal "water" noise during braking/acceleration | flyingprius | Gen II Prius Main Forum | 7 | 05-19-2008 06:35 PM |
| So no one saw the hybrid discussion on "Alias" las | priusenvy | Gen II Prius Main Forum | 2 | 03-19-2005 12:05 PM |
| What is "Brisk" acceleration? | FireEngineer | Gen II Prius Fuel Economy | 2 | 03-14-2005 10:58 AM |
